Headache Rack - Flood lights?
Discussion in 'Ask An Owner Operator' started by Hanadarko, Jun 27, 2012.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    I have a Road Gear Headache rack and looking for ideas for a pair of flood lights:
    The rack doesnt have a flat top. It's sorta a box top with 2 edges and an angle back, so I am not even sure how I can mount something.
    I called Road Gear and they dont even sell any accessory for this.
    I'd like to get a pair of decent LED spots or something but also need a way to mount them ??
  3. DEMO
    DEMO Money Bags
    480
    349
    Mar 6, 2012
    Orlando, FL
    I used an aluminum piece of angle iron and attached it to the top of the rack with self tapping screws. Then mounted the lights to the piece of angle. I used two small pieces, one for each side. I made sure I got the LED lights that could move 90 degrees within the light mount.
  4. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    Yea, that was my one thought....mount a plate and then mount the light to the plate.
    Any recommendation on an LED light that is bright?
    I found some they use in Alaska for the dark winters...dam things are like $275 each.
    Yea, they are bright but thats insane...
  5. DEMO
    DEMO Money Bags
    480
    349
    Mar 6, 2012
    Orlando, FL
  6. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Mr Hanadarko,here's a pratical idea for you.
    It isn't the easy way but nothing worth having is easy.
    At the top off the rack,between the back off the cab and the front off the headache rack(if you don't have enough room,you can do it at the other side off the headache rack but doesn't look as nice),you bolt a aluminium tube(have a few flat pieces welded to the tube) with self tapping screws.
    Then you insert 2 pieces off tube which are half the lenght(actually a little bit shorter) off the long tube which is fixed to the rack.
    Weld a flat piece to the end off each tube.There you can mount whatever light you prefer.
    On the long tube,at either end,you drill a hole and weld a Nut on it.
    In that nut you put a bolt with a small rod welded on it(so you can undo and redo the bolt without a wrench)
    What you then have are the only lights that will allow you to shine light on your entire trailer because you can extend then sideways.
    I have seen a few guys round here with that setup and it works.
    But like i said.............it will take some work.(no pain,no gain :yes2557: )
    Hanadarko Thanks this.
  7. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
  8. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
  9. DEMO
    DEMO Money Bags
    480
    349
    Mar 6, 2012
    Orlando, FL
    let me know how they work. How much were they? I did not see a price..
  10. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    I have used off road driving lights.
    I would not invest the money in LED's unless you use them all the time
  11. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    These sell for under $100 each. They are not terribly expensive and since I converted the entire rest
    of the rig to LED, it made sense to stay on course...
    :yes2557:
    DEMO Thanks this.
