HAZMAT Placards on Flatbed Trailer
Discussion in 'Flatbed Trucking Forum' started by Mikey Dee, Mar 30, 2016.
  1. Mikey Dee
    Mikey Dee Bobtail Member
    4
    Pascagoula, MS
    The bulk containers have placards on all sides - which are visible FROM all sides. My question is this: Since the bulk containers placards are visible, is it still required to placard the truck and trailer?
  3. Hyweighman
    Hyweighman Medium Load Member
    517
    659
    Dec 29, 2011
    Pensacola, FL
    As long as all containers are the same and can see placards, should be good to go.
  4. Mikey Dee
    4
    Pascagoula, MS
    No placard required in the front of the tractor?
  5. Hyweighman
    517
    659
    Dec 29, 2011
    Pensacola, FL
    No. As long as on front of trailer
  6. Mikey Dee
    4
    Pascagoula, MS
    So, if the placard on the front of the containers is not visible, put one on the front of the trailer. If the front of the trailer is not visible, put one on the front of the tractor..... Correct?
  7. Kast
    Kast Bobtail Member
    6
    7
    Mar 18, 2016
    NC
    The placards need to be on all 4 sides of the trailer - this way - if you drop the trailer - you are still compliant! However - with that being said - yes - it is legal if it is on the tractor instead - just don't drop the trailer!
  8. earlybird1104
    earlybird1104 Medium Load Member
    412
    95
    Dec 22, 2015
    Question how can a placard be put on front of the trailer I have a great Dane there's no room to put a placard holder
  9. macavoy
    macavoy Road Train Member
    1,092
    1,956
    Jan 3, 2011
    Houston, Tx
    Put it on your tractor
  10. solitary_con
    solitary_con Light Load Member
    147
    137
    Mar 2, 2007
    Cook County, IL
    If the bulk container placards are visible, there is no need to put them on the trailer.
  11. sawmill
    sawmill Road Train Member
    3,590
    66,720
    May 29, 2015
    Evanston, WY
    Just make sure they are the full size placards. The little mini placards that get put on totes are not enough to satisfy the requirements.
    Chewy352 Thanks this.
