Hazmat, and hauling diesel fuel?
Discussion in 'Hazmat Trucking Forum' started by Scout76, Dec 22, 2018.
  1. Scout76
    Scout76 Bobtail Member
    8
    I have a question about the Federal Hazardous Materials Safety Permit, and hauling diesel fuel. I have heard that you don’t need one for a tank that holds 3500 gallons or less. I have also heard that you need one for a tank that holds more than 119 gallons. Does anyone have any info on this? Thanks.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Are you hauling fuel or bio?
    You don't need it for bio.
    x1Heavy Thanks this.
  4. kemosabi49
    10,442
    44,426
    Jan 13, 2013
    SW Arkansas
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Straight fuel you do.
    You will notice in your Hazmat guide issued by year (If it is a really comprehensive one) that there are minimum placarding limits alluded to by Kemosabi49.
  6. Gumper
    Gumper Road Train Member
    1,557
    3,678
    Jan 7, 2018
    Butte, MT
    You’ll need a placard for bulk fuel over the 119 gallons. Thought it was 1001 lbs, but doesn’t appear to be.
  7. kemosabi49
    10,442
    44,426
    Jan 13, 2013
    SW Arkansas
    Op is asking about needing the "Federal Hazardous Materials Safety Permit". Not whether he would need placards or whether diesel is considered hazmat. FMCSA regs:
    What Hazardous Materials require a Hazardous Materials Safety Permit?
    The following hazardous materials carried in these quantity amounts will require an HM Safety Permit:
    • Radioactive Materials: A highway route-controlled quantity of Class 7 material, as defined in 173.403 of 49 CFR.
    • Explosives: More than 25kg (55 pounds) of a Division 1.1, 1.2 or 1.3 material, or an amount of a Division 1.5 material requiring a placard under Part 172 Subpart F of 49 CFR.
    • Toxic by Inhalation Materials:
      • Hazard Zone A: More that one liter (1.08 quarts) per package of a "material poisonous by inhalation," as defined in 171.8 of 49 CFR, that meets the criteria for "hazard zone A," as specified in 173.116(a) or 173.133(a) of 49 CFR
      • Hazard Zone B: A "material poisonous by inhalation," as defined in 171.8 of this title, that meets the criteria for "hazard zone B," as specified in 173.116(a) or 173.133(a) of 49 CFR in a bulk packaging (capacity greater than 450 L [119 gallons])
      • Hazard Zone C & D: A "material poisonous by inhalation," as defined in 171.8 of this title, that meets the criteria for "hazard zone C," or "hazard zone D," as specified in 173.116(a) of this title, in a packaging having a capacity equal to or greater than 13,248 L (3,500 gallons)
        • Due to Anhydrous Ammonia (ammonia, anhydrous) having both international and domestic entries in the Hazardous Materials Table (HMT)(See 49 CFR § 172.101), considerations must be made in order to determine the need for a Hazardous Materials Safety Permit (HMSP):
          • For Anhydrous Ammonia in “domestic transportation” (See 49 CFR § 171.8) and described as UN1005 ammonia, anhydrous 2.2 Inhalation Hazard, an HMSP is not required.
          • For Anhydrous Ammonia described as UN1005, ammonia, anhydrous 2.3 Poison Inhalation Hazard or Toxic Inhalation Hazard, Zone D, and when transported in a packaging having a capacity greater than 13,248 L (3,500 gallons), an HMSP is required. In these instances, Anhydrous Ammonia meets the definition of a Material that is Poison-By-Inhalation or Toxic-By-Inhalation as defined in 49 CFR § 171.8 and meets the criteria for a hazard zone D as specified in 49 CFR § 173.116(a).
    • Methane: A shipment of compressed or refrigerated liquefied methane or liquefied natural gas or other liquefied gas with a methane content of at least 85% in a bulk packaging having a capacity equal to or greater than 13,248 L (3,500 gallons) for liquids or gases.
    GasHauler Thanks this.
  8. MACK E-6
    48,131
    219,687
    Volume trumps the weight with liquids, and 119 gallons or more in 1 container also requires a tank endorsement, IIRC.
    brian991219 Thanks this.
  9. snowwy
    20,527
    13,262
    Jul 6, 2009
    Isn't there a 1,001 in there somewhere for something also?
    Seems like it was one of the questions for the endorsement.
  10. Gumper
    1,557
    3,678
    Jan 7, 2018
    Butte, MT
    Probably doesn’t apply to bulk tanks? 1,001 for 1.4/1.5 was the rule the last time I hauled it.
    snowwy Thanks this.
  11. MACK E-6
    48,131
    219,687
    1001 lbs is when a non-ID placard is required for a given class of table 2 you may have on board.
    snowwy and brian991219 Thank this.
