Having an issue with the pto light not going off.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by gasmask, Aug 26, 2018.
  1. gasmask
    gasmask Bobtail Member
    13
    5
    Aug 26, 2018
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    If the pto is off, and just the light is on your ok. Its most likely just a sensor, or bad wire.
  4. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Sounds like a short somewhere, mine was used sleeper by the frame. Small wear spot in shielding.
  5. gasmask
    13
    5
    Aug 26, 2018
    will it drain the battery down?
  6. gasmask
    13
    5
    Aug 26, 2018
    ok, it just started doing this like 2 days ago. appreciate the feed back
  7. gasmask
    13
    5
    Aug 26, 2018
    I appreciate it, will that battery be ok?
  8. cjb logistics
    766
    643
    Aug 13, 2016
    Liberal Ks
    Check the connect on pto, might have trash in it. Unplug it and run without it if it is your truck.
    My truck pto light was for telling you it was on, and to tell computer not to re-gen.
  9. gasmask
    13
    5
    Aug 26, 2018
    I'll try that cjb. my pto light is for same thing. I know its not on but the stupid light won't go off
