Having a problem with my Power Inverter, TUNDRA M2000
Discussion in 'Experienced Truckers' Advice' started by Marleaux7, Dec 7, 2024.
  1. Marleaux7
    Marleaux7 Bobtail Member
    Dec 6, 2024
    So basically every time I start my engine my inverter turns off then on again. I have my PS5, Modem and TV plugged into it so I can’t even watch TV or play my game if I want to be on optimized idle because once the engine shuts off and then back on it’ll turn everything that’s plugged into the inverter off then they all cut back on again, and that’s bad because it could damage my game system. Does anyone know what the problem could be or have a solution? Or should I just bring it to my terminal’s shop for maintenance. It’s a 2025 FreightLiner Cascadia. Any insight would be highly appreciated.
    tscottme Thanks this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,530
    18,015
    Nov 1, 2010
    Burnsville, MN
    I don't know. But if everything else fails to fix the problem you could put a UPS between the inverter and your devices.
    (UPS - uninterruptible power supply)
    That way, the inverter would be powering the UPS and the UPS would be supplying power to the devices.
    JolliRoger, MACK E-6 and snowwy Thank this.
  4. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    I seem to recall my inverter doing the same thing when truck was started.
    As mentioned above. Buy a power supply to power your devices. Use the inverter to keep the power supply charged up.
    JolliRoger and MACK E-6 Thank this.
  5. AModelCat
    154,582
    Probably nothing at all wrong with the inverter. The starter motor will suddenly draw a couple hundred amps when it starts cranking the engine. Just isn't enough power there to supply the inverter with the correct voltage for the couple seconds of cranking. Probably best to do as suggested above and get a UPS unit.
  6. tscottme
    tscottme Road Train Member
    Almost all vehicles interrupt ALL POWER during the moment starter is engaged. Some small, low current circuits are wired to the battery directly (unswitched circuits).
    Since inverters are expected to supply lots of power they are almost never connected as an unswitched circuit. What you could do is plug in an Uninterruptible Power System between your inverter & the devices you want to run continuously. They can power your devices for the few seconds in which your current setup looses power. You need to pick a UPS based on the total power need of your devices. There are online calculators.
    Arctic_fox Thanks this.
  7. Ridgeline
    22,116
    113,354
    STOP BUYING MODIFIED SINE WAVE JUNK INVERTERS.
    BUY A GOOD INVERTER THAT DOES THE JOB.
    I've been using the one at the link for the past 8 months and have had one failure.
    Amazon.com
  8. Concorde
    Concorde Road Train Member
    4,347
    15,457
    Jun 29, 2016
    West Melbourne Florida
    Disconnect all your truck batteries and put a volt meter to each one. Probably got one or two that aren’t healthy..bad cell or two.
    I got a battery going bad and I suspect it’s why my digital dash crashes every time I start it now..almost every time.
  9. snowwy
    20,527
    13,262
    Jul 6, 2009
    Somehow. I don't think it matters what's bought. They'll all shut off with the starter motor.
  10. 86scotty
    86scotty Road Train Member
    4,376
    11,620
    Aug 27, 2017
    Appalachia
    Inverters should be wired directly to batteries with the proper sized cable, which is to say BIG on most decent inverters, 2 gauge up to 1/0 or 2/0 even.
    If it's a decent inverter and your batteries are strong starting the truck shouldn't make any difference. The most I ever get is a low battery 'beep' from my inverter the moment the starter engages.
    If it's not your truck you probably can't modify this stuff much but you need a good inverter (PSW as Ridgeline stated above preferably), wired directly to batteries with the proper cable and fuses/breakers and you need good batteries which you know the condition of.
    How many batteries does this Cascadia have?
  11. Thoric320
    Thoric320 Bobtail Member
    This is an issue with that specific inverter. Been having same problem in my 2024 t680 apparently there's a recall on em there's a chip inside that has to be replaced for it to work properly cause it's not supposed to be cutting out if your truck has opti idle and your batteries are good
