The driver's field tank seems to run quicker on fuel than the passenger side and I noticed that it would be like 3/4 tank on the passenger side and driver side has a quarter tank I also noticed that the stem on the top the ventilation hose on the passenger side when my tanks are full of fuel the passenger side seems to be leaking fuel ever so often but the driver side does not leak at all would that be the cause of the fuel not leveling properly should I replace the top ventilation hose on that one side?
Having a fuel tank issue driver
Discussion in 'Ask An Owner Operator' started by Lxlive, Feb 18, 2021.
Some trucks have their fuel return to the right side and equalize with the left.
H3R3T1C Thanks this. -
It's not clogged I removed and blew it out. Would that be the reason why it's not flowing evenly?
If you follow the fuel lines to where they all go into a block on top of tail end of trans. That block has a valve that keeps the fuel at same level in both tanks, it may need to be replaced?
TallJoe Thanks this. -
Had a KW that did that to me once... Was a plugged return line to one tank. The inner lining of the fuel line had begun to deteriorate and some of it had flaked off and plugged the line.
