We haul sludge from dannon. WE have dry pumps. Pulls vacuum inside the trailer to load the sludge. Pressures the trailer to unload. Depending on what we're unloading in to.
Any of you hauled it. Knows how it stinks.
We've recent been told we can no longer use our pumps. Because of the smell that's sucked from the trailer and out the pump through the exhaust system in to the atmosphere. Makes no sense to me as the trucks only spend 20 minutes. And leave. There by the created smell dissipates in to the atmosphere. And is gone.
The tank, however is a 24/7/365 stink pit. THAT smell never goes away.
I was thinking of buying my own trash pump from harborfreight. But apparently any trash pump will plug up once the sludge level is low enough that instead of liquid, we're getting more of an oatmeal type of load.
The trailers have valves. The lids are never opened. The valves are used for releasing pressure or vacuum. The load/unload pipe extends out the back of trailer.
I haul 60,000 lbs. With the pump i can load fully in 20 minutes. Without the pump. I"m now close to an hour and and only 80% loaded. And THAT'S if the tank level is high enough to gravity load the trailer.
Needless to say. Without the pump. My days are pretty long now. And get even longer if i have to do 4 short hauls instead of 2 longer hauls.
I know i'm not the only one hauling stunky loads in this country. So, some of you must have OR know of methods that are being used for places that don't allow use of your pumps. Or are we ALL basically screwed and confined to the ever long loading times without a pump.
I'd like to get my days back to the normal amount of hours where i spend more time at home instead of at work.
HOW ARE UUUUU ALL BATTLING THE SMELLS FROM LOADS????
I don't know how long my company has been hauling for dannon. And why it's suddenly a big deal. And i certainly have no desire to extend my day by 2 or 4 hours. Because i can't use the pump.
Hauling sludge and the smell
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by snowwy, Nov 22, 2016.
So Danone doesn't even like it's own product? How thoughtful.
I've run septic trucks; talk about smell...
Look into what kind of exhaust filtration septic trucks use. As for loading by gravity, it won't eliminate the smell because the incoming product still has to displace the air in the trailer and thus will still create a smell in the area, but likely not as intense in the short-term.
As for the increased loading time; so long as you're getting paid by the hour it's all good. You're not getting paid by the load, are you?Last edited: Nov 22, 2016
Paid by the load.
A 10 hour day would give me a good hourly wage. I'm getting screwed with these 13 and 14 hour days. Not to mention HOS violations if we were on ELD. The 11 and 14 are allright but there'd be nothing left to work on regarding the 60 or 70 rule.Last edited: Nov 22, 2016
What difference does it make if you use the pump or not? The air in the tank still has to come out in order to fill it. Seems to me they would want the smell gone sooner rather than later.
I'm not understanding it either.
Light smell from the trailer valves for an hour. Heavier smell from the pump exhaust for 20 minutes. 24/7/365 smell from the tank that can't move. Not to mention the 3 manhole valves they got in the ground. Them valves REALLY stink. -
I don't understand this. My first trucking gig was pulling a wastewater tanker. Your boss needs to cut you guys some slack and leave that customer or explain to them the situation. My former employer put the drivers first as long as we using good judgement. If your boss doesn't have your back, start looking for another job. I got paid by the hour... I'd never put up with that load bs
The boss has our back, but dannon is the boss.
Other then gas haulers. i don't think many tanker gigs pay by the hour. If that were the case. We'd have a lot of mo fo's screwing around and not working.I can't imagine anyone paying by the hour. Considering how lazy drivers are.
Besides, what hourly wages there are. Aren't worth a crap. I average $25 an hour. If we can find a way to get back to using the pumps. Right now, I'm working for $18 an hour. Without the pumps. -
I feel ya man. They need to get over it and allow you to do the job the most efficient way possible. I will disagree with your statement on tanker work though. I've done wastewater, asphalt and crude oil, gashauling, and dry bulk tanker and have always been paid by the hour.
Air Cooled Thanks this.
