Hauling Lumber
Discussion in 'Flatbed Trucking Forum' started by superdutyfan, Jan 5, 2021.
  1. superdutyfan
    superdutyfan Light Load Member
    86
    76
    Mar 14, 2020
    I waz wondering if anyone has hauled truck loads of lumber and if so what are the good the bad and the ugly of hauling truck loads of lumber ? And which is better step deck or high boy? Assuming they are both 53 ft tandem trailers.
  3. Judge
    84,390
    Best have bigger boards in front and rear to jack up the front and rear bundels, or lumber can walk forward if you brake to hard, or just walk backwards on our smooth roads,
  4. HillbillyDeluxeTruck
    5,878
    29,941
    Mar 3, 2013
    San Antone
    Yup. 4x4's each under the front and rear.
    We only haul it all the time.
    superdutyfan Thanks this.
  5. AKDoug
    AKDoug Medium Load Member
    323
    801
    Mar 21, 2018
    I've hauled wrapped bundles of douglas fir and SPF framing lumber for over two decades. When banded and wrapped they are relatively easy loads. I strap the living snot out of them and have had zero issues hauling it. I don't use a step deck, just a standard 45' flat with spread rear axle. Stacked double high I run out of weight long before I run out of room. I'm lucky that I can go up to 88K lbs on my setup where I run.
    I have not had any experience hauling SYP, rough sawn lumber, or anything that is unwrapped.
  6. Qbf594
    Qbf594 Road Train Member
    1,641
    8,711
    Aug 15, 2019
    Southern Canadian annex, NY
    Don't know your region but I was shown the wedge loading down in the Southeast. In the northwest the loader got out and turned my back 4x6 on its side (in framing its called proud, the bigger dimension vertically) so that it was only 4" up not 6". I didn't see until it was loaded . up there they apparently don't see it done that way but it's good. I'd had a load shift forward before I learned that but never after I started doing it that way.
    Carrying (2) 4x6 guaranteed even if they have it strapped over large-ish sticker boards you can still get some slope to it for strapping. The gravity against the slope is more force than you can achieve with straps.
  7. D.Tibbitt
    140,736
    Strap it and go. Dont need a 53ft trailer for lumber
    Roger McG and superdutyfan Thank this.
  8. 6wheeler
    6wheeler Road Train Member
    2,696
    4,772
    Aug 30, 2009
    What's a high boy? Lol
  9. superdutyfan
    86
    76
    Mar 14, 2020
    Regular trailer not drop or step deck
  10. 6wheeler
    2,696
    4,772
    Aug 30, 2009
    Lol, I could be wrong but I've never seen a 53 foot tandem flatbed
  11. superdutyfan
    86
    76
    Mar 14, 2020
    I'm pulling one now
    Badmon and Farmtractor9900 Thank this.
