Haulin Stacks
Discussion in 'Flatbed Trucking Forum' started by Kansas, Aug 2, 2013.
  1. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Anybody got a link or some sort of documentation for proper chaining / strapping techinques for stacked trailers. Seems like every where i go, there's always confusion or confrontation as to the proper way to Secure these loads. I wanna print this stuff out as a justification to my actions.
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I wonder if JJ Keller could help you?
  4. TripleSix
    127,950
    Utility trailers or stacked semi trailers?
    Semi trailers, cover for the length and weight, and you will satisfy DOT. I would cross chain the fronts and rears each level and throw straps across the tops as mains.
    utility trailers? If they have the styrofoam blocks as dunnage, they're going to sway. Easiest way to secure them is with 2 inch straps and ratchet down the corners on each stack. Don't forget about the 3 tiers, 6 ft or taller rule. You're talking about a lot of straps.
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    1 binder each tire on deck
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Guess the OP isnt going to tell us what type of trailer huh?
    If flats/steps, go through the stake pockets at angles, like any other load.
    Certainly not brain surgery, so not sure why you would need documentation......
    Martin
  7. Kansas
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    How exactly would u stack utility trailers? Title of thread is called Haulin Stacks... Its obvious.
    What if the trailer has D Rings only? What if the dealer requires you chain only. What if the dealer requires only straps be used. What if the top trailer has a dove tail (no pockets or D rings) . The options are absolutely infinite.
    ive hauled plenty of stacked trailers, and everytime i do there is always a discussion about the correct way to do so. Setting in the truck stop, strapping/chaining at the factory, unloading at the dealer. Everywhere i go, guys want to discuss proper procedures. Thats what flat bedders do, they quest to perfect their art, and this includes me.
  8. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Well it wasnt THAT obvious but ive hauled lots of stacked trailers. I dont know the exact rules but what worked for me was chaining the bottom trailer if its a BIG stack and always pull both directions
    MichianaFlat Thanks this.
  9. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Also strap every layer. also keep your straps as close to the sturdiest parts of the trailer
  10. leftlanetruckin
    3,607
    3,160
    Mar 12, 2009
    Touchy...Any "additives" in your Cherio's this morning?
    I always run chains through the stake pocket. Pulling forwards and backwards, just like any other load. Like I said, it isn't brain surgery unless you make it so. Guess hauling equipment all the time makes some of us more confident etc? Dunno
    Last time I checked, D rings were also made for chains too...
  11. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    8 chains, 4 per side in a small zig-zag pattern.
