Has anyone used the Blue magic Seal-up liquid glass metallic
Discussion in 'Trucks [ Eighteen Wheelers ]' started by daviduma, Jun 16, 2019.
  1. daviduma
    daviduma Bobtail Member
    8
    Has anyone used the Seal-up liquid glass metallic to try to seal the engine block or radiator? Does it work for you guys. I’m trying to fix a leak that I have I changed the air compressor on my truck Columbia detroit 60 14 l because the coolant was leaking through there. But I see a tiny drop again. So I’m not sure if the block needs to be replaced. I’m trying to seal the leak but I don’t know if it will work or do any damage to engine. Please let me know if anyone had used it before.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    It contains sodium silicate. If it happens to leak into the oil, your motor will be junk.
    I might use it on an old clunker car but not an expensive truck engine.
  4. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    if he cant fix the engine the correct way. then does it really matter
    2013Maxx and cjb logistics Thank this.
  5. 2013Maxx
    2013Maxx Light Load Member
    135
    42
    Jan 17, 2018
    Old post, but I’m using K Seal HD in my International currently. So far so good. I had coolant coming out of my exhaust and steam coming out of the draft tube. It all cleared up afterwards..
