Hard Steering
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dillydog24, Nov 12, 2020.
  1. dillydog24
    dillydog24 Light Load Member
    66
    53
    Jun 8, 2020
    I have a tri axle dump that is very hard to steer at slow speeds when loaded. If I’m at a dead stop I can’t get it to turn. Even with all my might. Help?
  3. User666
    User666 Medium Load Member
    346
    888
    Sep 22, 2020
    Northeast Ohio
    Does it get easier if you bring the RPMs up?
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Check all front end components and make sure everything is free and moves lock to lock by hand while jacked up.
    From there pressure and flow check the pump dead head.
    Something is frozen or you have a weak pump. These are the 2 most likely issues.
    Dino soar, AModelCat and spsauerland Thank this.
  5. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Sounds like you have either lost the pump or the steering box is in bypass......either way you have no assist. This is one time you might want to take it to a mechanic and have them verify pump pressure as this could get a bit spendy if you just start throwing parts at it.
    Keep in mind i'm also assuming you trucks front end is mechanically sound and you have at least verified front tire pressure to be correct.
  6. AModelCat
    154,238
    Eat your Wheaties!!!!!
    Jokes aside, the above advice is spot on. Get it tested.
    6cuda6 and Dino soar Thank this.
  7. 6cuda6
    259
    176
    Oct 9, 2020
    Sheesh at one time Power Steering was an option, not the standard....that's why the older trucks had a BIG steering wheel....lol.
  8. dillydog24
    66
    53
    Jun 8, 2020
    Tire pressures are good. They are floaters. It turns okay unloaded, stopped. And bringing the RPMs up does not change anything.
  9. 6cuda6
    259
    176
    Oct 9, 2020
    Ill still say no assist or you've got a rear leveling valve that's putting all the load forward by adjusting to high.
    RepoweredRookie Thanks this.
