Handheld cb radios
Discussion in 'Questions From New Drivers' started by GettingRolling, Nov 25, 2020.
  1. GettingRolling
    GettingRolling Light Load Member
    166
    140
    Aug 30, 2018
    Hello all,
    Looking at starting with a new company and looking at non permanent cb options. Ideally something I can plug in for power and drop in a cup holder just to scan for traffic info.
    Knowledge is power and knowing is half the battle.
    Any recommendations and opinions would be appreciated.
    Have a great Thanksgiving and keep the rubber side down
  3. flybynight12
    flybynight12 Medium Load Member
    683
    539
    Jan 10, 2015
    slc
    They arent to good depending on your truck and other factors they only work for a mile or 2 if that helps honestly a cb like a basic cobra for like 40 bucks is just as easy and portable as long as your truck is speced for it already and if its not they sell vice grips where you can attach an attena and hang it outside it may take a few minutes but its easy i used to slip seat and did it every day.check out amazon
    tththey seem to have alot of offers and review
    GettingRolling Thanks this.
  4. FozzyNOK
    FozzyNOK Road Train Member
    2,452
    3,774
    Jul 18, 2007
    Oklahomistan
    Hand held electronic devices are illegal in CMVs. I would probably say that its not that great an idea.. besides the fact that I have never seen a hand held CB that worked at all. There are small CBs out there and you can get magnetic antenna mounts and it can all go together in minutes
    spindrift and GettingRolling Thank this.
  5. TripleSix
    127,950
    Hand helds don’t work well enough for highway use. We use them when we had to walk behind a superload and steer it around a turn.
    A Cobra 19 works much better and cost half as much as a hand held.
  6. Moose1958
    Moose1958 Road Train Member
    15,090
    33,172
    Dec 17, 2010
    Williesburg, Virignia
    The best use is what you see most of the time. As @TripleSix has said, and I have seen a lot of trainers using them with students.
  7. MACK E-6
    48,113
    219,512
    I was wondering about this myself, and was hoping what I first heard was wrong.
    This tells me it wasn’t.
  8. Moose1958
    15,090
    33,172
    Dec 17, 2010
    You can get a portable CB and generally, you should be able to hear most of what's going on around you. Might I recommend checking out a regular CB radio hooked to a magnetic stick-on antenna? I used to use these all the time in my POV. When I was doing repo I used one with a vice grip type holder. You have options.
    MACK E-6 Thanks this.
  9. LTL Bull
    LTL Bull Road Train Member
    1,561
    6,561
    Mar 12, 2020
    Old School throwback from the slip seat LTL’ers
    This ones pretty fancy though
    Bumper, Speed_Drums and MACK E-6 Thank this.
  10. MACK E-6
    48,113
    219,512
    That’s certainly the fanciest one of those I’ve ever seen.
    LTL Bull Thanks this.
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    president Lincoln plus. 10 meter. all digital.
