Hand Valve Brake
Discussion in 'Questions From New Drivers' started by Need4Speed, Apr 10, 2018.
  1. Need4Speed
    Need4Speed Light Load Member
    60
    26
    May 8, 2013
    What is the purpose of the Hand Valve Brake that's usually just to the right of the steering wheel? How does it work? Why is it used when coupling?
  3. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    • To make sure the 5th wheel is latched
    • To hold the trailer in position as you slide tandems
    • To check for application air leaks
    • To activate auto slack adjusters with 80+ psi. You can do this with the foot valve but sometimes I prefer to isolate the action to the trailer only
    • And a few other things
    Grubby, bottomdumpin, heyns57 and 3 others Thank this.
  4. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    It’s a hand brake for the trailer.
    There are some trailers that do not have spring brakes on them.
    In the event that a non spring brake trailer has sat unused for a length of time the air brakes can leak off.
    If you were to try to couple to it you could chase it all around the yard trying to get under it.
    The old school way to couple to a trailer is back the fifth wheel so it just contacts the front of the trailer.
    Then get out hook up air lines and light cord.
    Get back in the truck charge the trailer with air and then apply the hand brake you are referring to and the back under the trailer.
    So you see it would apply the trailer brakes when coupling so you don’t chase the trailer around yard trying to get under it.
    There are also a few other uses for it but not recommended.
  5. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    If you are an ice road trucker you use it to skid the tires around corners to make good TV
  6. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    You're showing your age, old man
    x1Heavy and Hulld Thank this.
  7. Need4Speed
    60
    26
    May 8, 2013
    @Hulld --
    very helpful. so what is the new-school way of coupling?
    Hulld Thanks this.
  8. Dave_in_AZ
    369,851
    It's primary purpose is to pull your trailer back behind you when you're getting squirrely in the snow.
    You GENTLY apply some brake to the trailer, and the tractor will pull it back behind you.
    x1Heavy, Hulld and Need4Speed Thank this.
  9. Kyle G.
    Kyle G. Road Train Member
    3,754
    19,604
    Jan 23, 2016
    Eastern Iowa
  10. Jwhis
    Jwhis Heavy Load Member
    862
    1,356
    Jan 17, 2018
    Two good uses
    1. Set it down to get out and make sure your brake lights work.
    2. Test your trailer service brakes
  11. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    3. When pulling someone else's trailer, use it going downhill to conserve the tractor brakes. Use their brakes instead.
    shogun, intrepidor, Aamcotrans and 4 others Thank this.
