Great. Oil pan threads came out with the plug.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TGUNKEL, Mar 16, 2014.
  1. TGUNKEL
    TGUNKEL Light Load Member
    229
    160
    Mar 16, 2013
    Spokane,Wa
    Went to service the truck today and when I pulled the drain plug out of the oil pan the freakin pan threads just happened to come out with them. On a Sunday. 3406E. Any suggestions. Need a place to start in the morning looking for.......parts?
    Gunk
  3. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    I think you can purchase an oversized self tapping replacement plug or maybe an insert. Take old plug with you, try NAPA or car quest.
    TGUNKEL Thanks this.
  4. TGUNKEL
    229
    160
    Mar 16, 2013
    Spokane,Wa
    Ok. Gonna try Cat first and see what happens. Thanks.
    Gunk
  5. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    I've helicoiled them before with success. But the best way is to remove sump and get a spud machined with the correct thread and weld it in.
    Cat sdp and TGUNKEL Thank this.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    The main reason for this is over tightening the drain plug when reinstalling. It is surprising the number of people who over tighten drain plugs and filters for fear of falling off. It is understandable, but everything has a torque spec, or tightening sequence. Cat drain plugs are only 50 foot pounds. Since the plug takes a 1 1/2" monster wrench or socket it is very easy to over tighten them when reinstalling. Use a torque wrench, no worries!
    BoxCarKidd and TGUNKEL Thank this.
  7. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    Be thankfull that the plug is out. The threads pulled on one of my tractors last summer and now the plug turns but won't come out. Fortunately, it doesn't leak But still haven't figured out how to get the #### thing out. I tried pulling VERY hard with vicegrips while turning hoping the threads inside the pan would catch but no go and removing the pan isn't really an option. In your case, I would tap t the next size and put a femco plug in it. I have femco's on all my trucks and wouldn't be without one.
  8. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Just one of several reasons I always change my own oil.
    LTK gonna have to break out the drill!
    mtoo Thanks this.
  9. Licensed to kill
    830
    2,434
    Dec 31, 2010
    Alberta
    Trying to avoid that. It would be quite messy and once I'm through, I'm committed. Going past the point of no return makes me nervous when I'm doing something I have no experience in. Been trying to find something that will pump the oil out of the dipstick tube, I thought they made something like that for marine use but the tube is AWFULLY small.
  10. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Heavyd Thanks this.
  11. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Don't you have a second plug on the other side? My C 15 has 2, lucky for that, the driver side one is stripped (corners that is).
