Great Dane reefer trailer repair.
Discussion in 'Refrigerated Trucking Forum' started by Snailexpress, Sep 15, 2021.
  1. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Screws holding lower scuff plate to the trailer are coming out during transition. Then unloading guy will break, damage load. Any good fixing technique?
    Found one repair shop but they have to drill holes outside thru the wall.
  3. 062
    062 Road Train Member
    6,141
    33,150
    Oct 20, 2013
  4. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    You can push the scuff plate tight with load locks and add more screws but if they're tweaked bad they will just pop out again. If they're bad the only way is to cut the weld and replace the section or whole length. A lot of aluminum welding.
    062 and Snailexpress Thank this.
  5. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    I can't add more screws. Metal sheet screw holding scuff plate to the wall post. I'm looking for something like blind rivet nut to put it on the post then set screws with locktite Screenshot (20).png
  6. wichris
    4,243
    8,447
    Jan 17, 2011
    Drill them out and put nutserts in with bolts and washers. But if they're that tweaked up it still will not hold long.
    Snailexpress Thanks this.
  7. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Lumpers can destroy anything pushing against the wall.
    Speed_Drums Thanks this.
