Anyone put be at oil on 5th wheel? It stays on there and excess doesn't drop ovet suspension/frame etc. Its designed for metal to metal lubrication so I think its good alternative to regular grease
Greasing 5th wheel with gear oil
Discussion in 'Ask An Owner Operator' started by mitmaks, Aug 13, 2021.
Page 1 of 6
Disagree. I've tried straight Lucas, semi liquid synthetic, and cheap grease. Cheap grease works better, and doesn't attract as much dirt as the others.
John E. Thanks this. -
A tube of regular grease is like 3 dollars. A bottle of diff oil is what 15?
Grease 5 bucks at wal mart vs 9 bucks for gear oil that can last 10+ applications vs tube that lasts 2-3
D.Tibbitt Thanks this. -
bzinger, shatteredsquare, mitmaks and 1 other person Thank this.
Speed_Drums and 86scotty Thank this.
No-Lube top plate is the best invention ever. No grease anywhere except a little on the jaws to keep them lubed up. Or if you pull your own trailer a Teflon disk on the trailer is also better than grease.
RockinChair, TallJoe, skytrash and 4 others Thank this. -
Your going to need to apply oil about 2 to 3 times as often as grease... Its just going to flow out to quickly.
Grease on the other hand isnt going to flow ANYWHERE... It will continue to smear around until its all squeezed out around the 5th wheel plate.
I could see using some old gear lube in a pinch if its all you had available... But it would be a very short term fix. -
Page 1 of 6
