Greaseless/sealed U-joints
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hurst, Mar 22, 2017.
  1. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    What is the service life of these things?
    I check mine everyday. No visible things I can see or feel. Even jammed a pry bar in there a few times to check for play. Seems good to me.
    Reason I ask is because I am approaching 1.4 million on this truck. I've been in it since 875k. I bought it from my carrier who has had it since 650k. He has no record of them ever being replaced. So at the very least,.. I'd say its safe to assume they have close to 1 million on them.
    Should I be concerned? Should I let it ride until I find some play,.. or just be safe and replace them with greaseable parts?
    Thanks,
    Hurst
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I have seen one fail at about 750,000. It was never loose. It took out a high dollar brake valve, 2 chambers, one air bag and a tow bill. Replace them all !!!! If anyone has one with low mileage they have a plug in the middle of the joint. You have to take the straps off to get to them but can install grease fittings. Then there are the other ones. While you are at it take the plugs out of the S-cam housings and slack adjusters. Install grease fittings and grease them also.
    Hurst Thanks this.
  4. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    The sealed joints are the way to go. The greasable actually don't last as long generally. It supposedly has to do with the end caps having a better seal to keep abrasives out.
    Anyway, 750k is all i would go and just change them out. Better safe than sorry.
    daf105paccar, BoxCarKidd and Hurst Thank this.
  5. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I have seen the carnage. Part of why I am posting this.
    This truck came with grease fittings on the slack adjusters and S-Cams. Trailer has them too.
    Hurst
  6. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Thats what I figured. I am anal over preventative maintenance. Much cheaper than the carnage that could happen.
    Thanks guys.
    Hurst
    KB3MMX Thanks this.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I have one failed at 780.000 ( front drive axle input) . Rest of them failed at 1.2-1.4 million miles. They were Meritor RPL series u-joints.
    Hurst and KB3MMX Thank this.
  8. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    All you can really do is disassemble it from the yoke and move the end caps by hand and feel for any binding and excessive play. It is also a good idea to check the slip yokes too to make sure they still slide in and out nicely. Once those seize they will send vibrations that will take out your trans and/or diffs.
    Oxbow, Hurst and SAR Thank this.
  9. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I have conventional u joints. They get examined monthly. I find once they get some up and down play in them you are on borrowed time. That being said ive run them for 6 months or more after finding a little up and down play. Like a 1/16" once it starrs getting worse rhen they get changed. If there is axial/ twisting play then they are are changed immediately. I also watch for the caps turning in the yoke. You should be able feel the roughness in the truck when its under load when the trunnion gets pitted and starts eating up the rollers.
  10. bzinger
    bzinger Road Train Member
    16,598
    65,780
    Dec 10, 2014
    omaha , ne
    I had a 2000 century that I bought with 500k on it with sealed joints .
    Replaced the first one at 550k and by 700k I had replaced them all .
    Not all were bad tho just replaced them while the shaft was off .
  11. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Got a load taking me back to Fla tomorrow.
    Was bringing truck in for annual inspection anyway. Now I have a small drip coming from the bottom of the radiator. Cant see where the source is. Radiator is only 1 yr old. Hoping its from a hose. Been raining all day here. Hard to find the source of a leak when everything else is wet too. If its not one thing its another.
    Going to have my guy replace the u-joints and check the shafts and everything while he is at it.
    Thank again,..
    Hurst
    Oxbow Thanks this.
