Grease vs. oil filled hubs
Discussion in 'Flatbed Trucking Forum' started by MJ1657, Aug 2, 2012.
  1. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Were looking into getting a new 53' trailer. What hub type do you guys think is better?
    SAR Thanks this.
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
  4. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    Depends on your application. Oil and grease both have advantages and disadvantages
    MJ1657 Thanks this.
  5. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    care to expand?
    I got my trailer with grease hubs and am considering converting it to oil.
    MJ1657 Thanks this.
  6. sickofbolts
    sickofbolts Bobtail Member
    27
    10
    Jul 23, 2012
    california
    OIL!!!! U can easily see if your bearings have lube and spot problems sooner. grease will let things sneak up on you. oil lubes much better, however, u can have a seal leak and loose your oil real fast while grease will stay in. when i was in the shop grease bearings failed much more than oil. i replaced 10 grease to 1 oil. just make a stedfast routine of peekin at your oil level everyday and watch the inside of the drums and tires for signs of leaks. carry a quart of lucas engine oil additive. if you spot a leak top off the hub with lucas and it will drastically slow the leak till you can repair it.
    mhyn, Laudwig Trucking, CAXPT and 2 others Thank this.
  7. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Oil
    Having both over the years oil is better and you can change the oil faster than cleaning and repacking grease hubs.
    CAXPT Thanks this.
  8. Shaggy76
    831
    307
    Feb 22, 2012
    Orlando, FL
    If trailer is used every day then go with oil, but if trailer will be sitting you want grease. Problem with oil is if trailer sits for a few weeks, seals dry out and you have leaks. That is why dry van companies use a lot of grease packed.
    If hauling heavy weights all the time, you get more life out of grease than oil filled with your bearings. You can do both. See it all the time on buses and some new Stoughton trailers I've worked on. They coat the bearings in grease then top off with oil. Some rg trailers are that way as well.
    If in the south every day, grease filled due to better control with heat. If in north, oil is better for grease will freeze at -12 and you'll have bearing loss before it heats up.
    Like I said, depending on application. On failures with grease over oil, working in the shop and doing the repairs I've repaired more oil filled than grease filled. I've had more bearing failures with oil filled. Grease filled is usually improper packing during install. If you pull caps at each brake change for repack you will get better life than oil filled. Most are cheap and don't want to spend the extra hour of labor to repack the four wheels.
  9. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    adayrider Thanks this.
  10. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Anyone have anymore info? I have my first grease trailer ever and clueless on what to do.
    If I keep the grease, what kind do you pack them with?
    What does it take to convert to oil? Just new seal and hubcap?
    What do I do if I want a mix? Just install oil hubcap and some oil?
    It's driving me nuts I can't see in there.
  11. adayrider
    1,289
    1,732
    May 7, 2018
    After reading that I think I will convert to oil at the next brake job I do.
    mhyn Thanks this.
