Grease in trailer axle bearings instead of gear oil?
Discussion in 'Flatbed Trucking Forum' started by ichudov, Jul 7, 2018.
  1. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    I have two semi trailers, which leak gear oil from the spindles/axles.
    The problem is that they leak on the INSIDE side and the reason for this is not just bad seal, but rust and pitting of the area where the seal seals.
    So, a change of seals would not help. Someone suggested to just replace gear oil with grease, pump the bearings totally full of grease and then just forget about it.
    I do mostly city and short distance trucking such as most 60 miles distance, 95% of the time.
    I often run heavy and occasionally overweight.
    Would that grease work in bearings?
    jamespmack Thanks this.
  3. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    The grease works as a lubricant, yes....
    However, once the bearings in the hubs gets up to operating temperature, the grease will solidify. Thus, making it a liquid with the consistency close to gear/hub oil.
    So basically it's not gonna solve your problem. Prolly best to get a spindle sleeve or a stemco style seal that incorporates a wear sleeve that fits onto the seal area of the spindle.
    Good luck
  4. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    there are high temp greases that do not liquify until, say, 400-500F... Would those work?
  5. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    I've never tried that, so I couldn't say.
    Thing is, those hubs are gonna build pressure no matter what you do. Even though the cap is vented, the pressure is gonna take the path of least resistance. I would think it would push the grease out no matter what. Also, grease that thick would be a nightmare in the winter if you live in cold temps.
  6. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    By manufacturer grease is semi liquid to flow around bearing rollers to grease and cool. If grease do not liquify the bearing will get hot and destroyed. Maine cause of hub fire btw if you ask me. And spindle will be destroyed too. Cheaper to do proper repair with sleeve.
  7. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Try STEMCO Voyager seal it will help
    Dave_in_AZ and Rideandrepair Thank this.
  8. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    Could use axel surgeon.
    snowman_w900 and SAR Thank this.
  9. truckdad
    truckdad Road Train Member
    2,020
    16,622
    Dec 14, 2014
    Penn Valley, CA
  10. 34kw
    34kw Bobtail Member
    47
    55
    Jul 28, 2010
    Montana
    Stemco Guardian is made just for this reason. If your spindle is extremely pitted, a little high temp silicone between the spindle and the steel liner should solve the problem.
  11. Dave_in_AZ
    369,691
    The zerk ( grease fittings ) on your axles are actually pressure relief fittings. If you or someone has changed those fitting to regular's, you have to be REAL carefull how you grease those, or you will forever have the problem.
    Snailexpress and ichudov Thank this.
