Got to put a gladhand seal on it.
Discussion in 'Questions From New Drivers' started by TommyTrucker88, Jan 10, 2018.
  1. TommyTrucker88
    TommyTrucker88 Light Load Member
    161
    133
    Nov 16, 2016
    POCONOS, PA
    Hey guys I had a question that I've been meaning to ask and get a actual answer to it.
    I do a lot of runs thru Laredo TX and it's the only place I noticed this issue.
    A lit of times here when we grab a trailer that cane across Mexico it ends up missing it's rubber seals/gaskets that go on the trailer gladhand couplers.
    The company shop keeps boxes of them on hand because it's a common problem.
    I heard one person say they steal em and then smoke em. I find it less plaussable then what I think it's taken for Wich is making there own tattoo ink. But is rubber that hard to come by?
    Have you guys running thru around this area or others noticed and know why they take them?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,525
    18,010
    Nov 1, 2010
    Burnsville, MN
    Not sure why they are missing, but in Laredo it does seem to be a problem.
    Nearly every time I pick up a trailer at the Swift terminal, the seals are missing. So I have to walk in to the shop to get more, and they only want to give me two.
    And that seems to be the only place it happens.
    tscottme, Grubby and TommyTrucker88 Thank this.
  4. Chinatown
    Chinatown Road Train Member
    73,324
    164,825
    Aug 28, 2011
    Henderson, NV & Orient
    That's odd.
    Used to the big problem was reefer units and tires being swapped out before returning the trailers to the border.
    Hammer166, Grubby and TommyTrucker88 Thank this.
  5. Txdriver77
    Txdriver77 Medium Load Member
    365
    26,641
    Sep 7, 2016
    Texas
    they still do that. at my last company we had brand new trailers come back across with rusted wheels and junk tires. all the oldler trailers had orange paint marks on the tires and wheels. the gladhand seals is just something else for them to steal.
    Grubby, x1Heavy and Chinatown Thank this.
  6. Moosetek13
    14,525
    18,010
    Nov 1, 2010
    Burnsville, MN
    This has been happening for years.
    When I asked the shop about it I was told some garbage excuse about the driver wanting to keep the seals for some reason.
    It is probably the shop collecting them, just to make things difficult for the drivers.
  7. Moose1958
    Moose1958 Road Train Member
    15,094
    33,186
    Dec 17, 2010
    Williesburg, Virignia
    This is a problem and has been for a long time. As a driver you need to keep 8 or 10 of these gaskets for times like these and others when you get a trailer with a busted one and it won't hold air. Just make sure you get the low profile gaskets. There are 2 kinds. I got stuck there once and all I could get my hands on was the thick ones. If you ask around in one of your shops most mechanics will give you a handful.
    Grubby and x1Heavy Thank this.
  8. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    They are used on trucks and trailers down so. of usa and come back missing every/thing thats not welded on!
    Hammer166, tscottme, Grubby and 3 others Thank this.
  9. Moosetek13
    14,525
    18,010
    Nov 1, 2010
    Burnsville, MN
    Gladhand seals can not be stolen before they arrive at the terminal on the U.S. side.
    Grubby, Highway Sailor and Aamcotrans Thank this.
  10. Moose1958
    15,094
    33,186
    Dec 17, 2010
    Yes, that is right. However once the driver drops the trailer they pull the gaskets off. I have seen this so many times. I remember getting a quick peek into a tractor and could see a small bucket. The driver looked like he had put something that was in his hand in that bucket.
  11. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    When I worked for PAM I took the seals off the trailer I dropped in Laredo so I had them for the trailer I picked up.
    Grubby, mindes, ncmickey and 3 others Thank this.
