got a tiket for hauling over size hay!!!!!
Discussion in 'Trucking Industry Regulations' started by BAYOU, Sep 20, 2011.
  1. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    In mississippi two weeks ago everyone tells you no need for permits flags or anything its bull
      File size:
      159.5 KB
      669
  3. nuts&bolts123
    nuts&bolts123 Light Load Member
    119
    51
    Aug 16, 2011
    bensalem pa
    any load wider than trailer, longer,or over 13,6 falls in oversize load(wide load ) category. plus if your not sure label it any way. but most importantly check with state d.o.t do not assume anything someone tells you.
  4. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    You would be incorrect sir. My trailer is 96" wide, legal width is 102" so I can legally hang 3" off of each side. Length laws vary by state, as do height laws.
    Bayou hotshot, you must have been hauling round bales. Texas did away with the overwidth requirement on them a few years ago but I don't know if that's still in effect. It's interesting that MS would have a specific permit for hauling wide hay. Thanks for the info.
  5. nuts&bolts123
    119
    51
    Aug 16, 2011
    bensalem pa
    yes ,yes, yes but your 96 over hanging 3" on a non 102 road way is oversized. but not trying to get technical just saying dont assume. and yes, yes ,yes depends on state for height etc. just sayin those 3 things should have you make a phone call first before assuming anything. plus whos to say he was pulling a 96?
  6. passingthru69
    Glad you got a ticket hauling those big round bales.They should be outlawed hauling side by side.
    It can be reduced in size. Got clipped years ago by one of those haulers and he just kept one going.
    Cops finally caught him.
    and he never knew he hit me and then to top it off he lost one of the bales and did'nt know that either
  7. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    But this guy did not hit you nor is he going to change how the industry moves a certain product.
  8. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    It only makes sense that anything 10'6" wide should need a permit.
    Most states require a permit, some do not charge for them. Some states waive the permit during a crisis, but only for a few weeks.
  9. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    I always wondered about that. You see farmers running around here with 3 round bales wide hanging a couple feet off each side with a row of two stacked up top. They can get away with it while truckers engaged in commerce have strict laws. They have no flags or signs either.
  10. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Any load wider than 106 inches can be ticketed without a permit for motor carriers, depends on how much they want to write a ticket.
  11. aiwiron
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Some states exempt agriculture loads if hauled by the point of origination,
    in most states they are not even required to have a CDL to operate the truck.
    http://www.fmcsa.dot.gov/rules-regulations/administration/rulemakings/notices/Agricultural-Guidance.pdf
