I got a new Big Tex gooseneck flat bed. I needed the "monster ramps" and I give them 2 thumbs up. The rest of the the trailer not so much. But I regress.
On my old trailer I was able to mount the winch about an inch above the deck and I really had no problems with it. However, on this new trailer due to the way it is built, the best location to mount the winch is about 3 feet above the deck. Has anyone mounted the winch that high on their trailer? Any problems? I am loading inop cars, trucks, and tractors with the winch.
Gooseneck Winch Location
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Slay, Feb 12, 2017.
We've mounted the both ways, up high, down low. Anytime we needed the cable low to the deck we just ran a chain across the trailer from side to side, and ran the winch line under the chain to hold it down. That works. You can also weld a D ring down low at the front of the trailer and use a Clevis/shackle,or snatch block to run the cable low.
Slay Thanks this. -
My thinking was the same as yours i.e. the chain and a snatch block to get it lower. I was wondering if anyone had run into other problems with the winch up higher.
I purchased a Reese hitch for under a step bumper and turned it upside down and had it welded toward the top of the gooseneck. With the winch mount that goes into the 2 inch receiver I can now have a winch or not as needed.
The welder liked it up high, in order to avoid the cable dragging on the break over point of the trailer.
Just food for thought. -
I also used a receiver hitch on my 40' Lowboy . My thought was, this way I could easily transfer it to my 20' bumper pull if I needed to. Great minds think alike. LolLast edited: Feb 14, 2017
