Goodyear Endurance LHD ($7650) what is your experience with them?
Discussion in 'Ask An Owner Operator' started by Coronado2020, Apr 16, 2022.
  1. Coronado2020
    Coronado2020 Light Load Member
    50
    139
    Jul 7, 2020
    AZ
    Removed all Michelin XDA Energy @282,000 Miles ( depth on all was 7/32) original rubber that came with new truck ( 2 years old ) after one blew the other day just a couple miles from TA in Arizona. I was gonna get Michelin again or Bridgestone and the guy laughed and said he didn’t get any in months so the most expensive and best tires he had in Tier 1 were these Goodyear Endurance LHD. They gave me $650 credit for mine and ended up paying $7,000 out the door price for everything. I never ran these Endurance Tires. Does anyone have any info on them. I had them for just a few days and so far it’s been a very smooth ride, running them at 105 PSI .
    D.Tibbitt and Vampire Thank this.
  3. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    Could've got 8 Michelin XDN2 here for 4800$. Not a GY fan personally
  4. goga
    goga Heavy Load Member
    894
    1,586
    Nov 11, 2021
    Earth..
    You had already put them on and paid, what's the point of asking if they are any good if there are no other options avail? From what I've seeing since last year, if I can find a FULL set of drives anywhere and I needed them, I'd get them regardless of brand.
    Running Toyo second year for 3600, no complaints on the rubber.
  5. Coronado2020
    50
    139
    Jul 7, 2020
    AZ
    I was just wondering because I never ran any GY tires in past that’s all.
  6. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    They seem expensive to me but hopefully do you a very good job. Keep diligent on the tire pressures but as many miles as you got out of the Michelins I’m assuming you do so.
    I wouldn’t look backwards at this point. What’s done is done.
    Edit: Replace your shocks as well to protect your big investment. They’ll be going sooner then later and will ruin your new tires once bad.
  7. goga
    894
    1,586
    Nov 11, 2021
    Earth..
    They are ok if ran gently. Heavy and speed will cap them over time. I've had Kumho, a kind of cheap option a while ago, had replaced them at 430k mi. So it is up to the use, not the brand. And yes, I have Centramatics all over 18 wheels.
    PS: 105 pressure is ok for winter, summer will eat sides, as heated air will "bubble" tires and longer diameter in the middle will chaff the shorter sides.
    Coronado2020 Thanks this.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    Thats what Schneider uses for drives.
    77fib77 Thanks this.
  9. Coronado2020
    50
    139
    Jul 7, 2020
    AZ
    I check tire pressure weekly and replace shocks every 80/90k miles.
    Vampire, Midwest Trucker and goga Thank this.
  10. goga
    894
    1,586
    Nov 11, 2021
    Earth..
    I check pressure twice a year, or when I see one lower than the other, and replace chocks every 50k if no leak earlier detected)
  11. Terlingua
    Terlingua Medium Load Member
    487
    1,019
    Oct 24, 2021
    Schneider uses Goodyear recaps on the drives.
