Glad Hand Connectors...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nitroglyc, Feb 2, 2014.
  1. nitroglyc
    nitroglyc Bobtail Member
    36
    10
    Apr 13, 2009
    Fairview, TN
    Ok, so I was put in a different tractor a couple of days ago, yesterday was my second delivery, both times the blue side glad hand on the trailer (rail chassis) was broke near the grommet. Picked up a trailer at a Kimberly Clark yesterday drove to Fairview, TN, and after I got backed into the spot at the flying j, I seen that yet another glad hand had yet again broken near the grommet... I don't understand why this is happening and only to the service side and not both service and emergency sides. Any ideas?
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    On your next hook up, make your connections, then make a sharp turn so your truck is about a 45 degree angle to the trailer. Stop, park your brakes, and check out if there are any clearance issues between the trailer and the back of your truck and check the trailer air lines have enough slack. Do this again at about 90 degrees.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    pay attention on Wabco DuoMatic connectors. I use it. much better any glad hand
  5. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    if not a clearance problem try changing your gland hand rubbers to a some other type that you dont have to put alot of pressure on in the cold weather. the black rubber ones always went on better than the red and blue plastic ones. lots of luck with that problem
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    I'm not exactly sure what you are saying? The metal glad hand is breaking? Is this happening after you pick a trailer up? If so I'd assume you have your fifth wheel too far forward?
  7. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Pictures? Are these trac chassis or jbhunt chassis?
  8. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    Thanks for the info. Those look nice, now to find a supplier stateside. I've been looking for a better way to handle the air connections for a while now.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Duo Matic is M16X1.5 threaded, so u need two metric fittings. I switched to duo matic and no any air leak
