Getting Computer Diagnostic Tool For Cummins
Discussion in 'Ask An Owner Operator' started by Shotgun94, Aug 18, 2018.
  1. Shotgun94
    Shotgun94 Medium Load Member
    446
    301
    Sep 24, 2017
    Georgia
    Does anyone have the diagnostic laptop or code reader for a 2012 cummins isx 2250?
    I don't know a lot about it and I see prices for these tools of up to 3k or even more.
    I want to be able to fix my own things for example say I want to reset my dpf after changing the filter or I change an injector and I want to reset the truck after fixing it.
    What should I get so I can read my codes and be able look at my parameters and adjust them?
    How much should I pay for it?
    Anyone use INSITE and how much is it?
    I seen Petro use the Jpro. Is that as good?
    Will it be a PITA to figure it out without messing up the ecm or other things on the truck?
    Thx for feedback.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I use Insite, it does a lot of things besides just read codes. You can run Diagnostics, do Regens, Cylinder cut out tests and also run it going down the highway to see how your engine is performing. The thing you can't do is make changes to the ECM, so if you want to kik your power up or your speed you will still need a shop for that.
  4. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    You can buy the software and reader online Ebay for 500.
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    EFIlive just released their Cummins HD software and programming tool.
    Yes... You can diagnose and custom tune your truck.
    20 Mule Team Thanks this.
  6. Ridgeline
    22,103
    113,210
    The reader isn't the issue, the software that some are selling are pirated versions even though they say they are not.
  7. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    So do i just download it on my laptop? And but the plug in kit?
  8. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    Of course they are. Insite is 2k a year cracked copy works just as good lol
  9. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    Correct
  10. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    Any links or ones you recommend?
