Getting air back into tandems after sliding--what am I missing?
Discussion in 'Experienced Truckers' Advice' started by GreenMonster9669, Jun 30, 2016.
  1. GreenMonster9669
    GreenMonster9669 Medium Load Member
    356
    332
    Aug 16, 2014
    St Louis
    I just took a job on a dedicated local run and make a daily delivery to a place that requires that I slide tandems to the rear and after bumping the dock I disconnect from the trailer and pull forward. Fine, no problems
    When it's time to leave I connect to the trailer, hook up the lines and pull forward enough to close the trailer doors. When I pull the air control knob to retract the tandem pins, nothing happens. How do I go about getting air back into that system? I've tried releasing the trailer brakes and pumping the service brake, nada.
    By the time I get to the gate there will be plenty of air to slide normally. So what am I missing? How can I get those pins to retract while I'm at the dock?
  3. tinytim
    tinytim Road Train Member
    5,143
    18,067
    Oct 29, 2007
    Northern Ontario
    I think you answered your own question. By the time you get to the gate it's aired up. In other words, it takes a bit of time. You just need a little patience.
    25(2)+2 Thanks this.
  4. 25(2)+2
    18,749
    45,387
    Sep 18, 2006
    the road less travelled
    The air release draws pressure from.the main tank, which is exhausted when you pull the supply knob.
    When you push the knob back in, the spring brakes are released first, and not always immediately, then the tank gets up to operating pressure, the airbags come back up to ride height, and the pin release will work again.
    Immediacy is an advantage to a properly functioning manual release, there are other advantages, as well.
  5. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    Does your trailer require the brakes to be set to pull that knob to slide the tandems? Does it also dump all its air when the trailer brake is set? Seems to be most of the newer trailers with air slide tandems operate that way. It's a nuisance like that...here's my routine.
    1. Release brakes, pull forward, set tractor brake only, go shut doors. Trailer will continue to air up.
    2. Set trailer brake, pull tandem slide knob, adjust. There should now be enough air in the system to move the pins. Takes about 100 psi, maybe less if the pins are well lubed or the trailer is brand new.
    3. Release trailer brake, which should lock the pins as well as the system airs back up. Check pins and roll out.
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    They generally need 100-110 PSI to actuate and hooking up and having to inflate the bags [with lots of weight?] and recharge the complete system can take a bit of time for the trailer reserve tank to reach 105+ PSI in addition to all the other systems demanding air.
    Ryan423 Thanks this.
  7. GreenMonster9669
    356
    332
    Aug 16, 2014
    St Louis
    Thanks guys, that's exactly the info I was hoping for.
