Georgia CDL Restriction "O" - Tractor Trailer
Discussion in 'Trucking Industry Regulations' started by smbartl5, Oct 24, 2014.
  1. smbartl5
    smbartl5 Bobtail Member
    Hello everybody, my name is Scott, I just got my Class A yesterday, but was placed with an "O" restriction and have a question.
    So the scenario is I tested in a 2007 Freightliner M2 Sport Chasis (19,500 GVWR on the sticker) with a fifth wheel / kingpin coupling pulling a 43" enclosed motorsports trailer (16,800 GVWR). The Freightliner is automatic with hydraulic brakes, air system only controls the parking brake and the air bag suspension, so I have an L and E restriction, which is appropriate, not allowing me to drive manual or air brake equipped combinations.
    However, they have placed an "O" restriction, which means I tested in a truck-trailer combination and that I cannot operate a tractor-trailer combination.
    The issue I have is first, the Freightliner is registered as a Tractor, and according to the US DOT FMCSA Definitions, it meets the definition of a "Tractor";
    (c) Semitrailer means any motor vehicle, other than a pole trailer, which is designed to be drawn by another motor vehicle and is constructed so that some part of its weight rests upon the self-propelled towing motor vehicle.
    Truck means any self-propelled commercial motor vehicle except a truck tractor, designed and/or used for the transportation of property.
    Truck tractor means a self-propelled commercial motor vehicle designed and/or used primarily for drawing other vehicles.
    Second, I called the Georiga Motor Carrier Compliance Division and spoke with an inspector at a weigh station who advised that if I was driving the combination that I tested in, which is registered as a tractor, and meets the minimum 26,001+GWVR combination weight minimum for a class A, that I cannot drive it with an "O" restriction, and that restriction needs to be moved.
    Third, both of my co-workers tested with the exact same setup at two different offices at two different times, and did not receive an "O" restriction.
    So I went back to the DDS office where I tested, spoke with the test proctor as well as the location's manager, who continued to advise that I am not driving a tractor-trailer, as to be considered a "tractor", the tractor itself has to be over 26,001 GVWR, but could not supply where in the CDL manual or Georgia code it stated such. I continued to show them what the US DOT considers a tractor, and that the vehicle is registered as a tractor, as well as the Georgia MCCD Inspector advised me, but all of that information was dismissed.
    Does anyone have any advise or shed any more light on this? It's near impossible to find definitions and more details on the "O" restriction.
    Thanks for your help.
    -Scott
  3. dptrucker
    dptrucker Road Train Member
    4,671
    3,181
    May 14, 2012
    adelanto,ca.
    go get a tractor-trailer with manual and airbrakes and retest. that way it removes all the restrictions
  4. allisonisatranny
    allisonisatranny Light Load Member
    188
    131
    Oct 6, 2014
    Okay, here's the deal.
    While it is a stretch to say the M2 sport chassis is a tractor, it is. But, I can see why they are trying to say its not.
    IF you look at the legal definition of a Class A license, you are required to have it when driving a combination vehicle pulling a trailer with a GVWR of 10k or more. It doesn't matter if you are driving Freightliner box truck and you have a 10k, you can test in this truck and get a Class A license if the trailer is rated 10k or more.
    Again, this particular office needs some intervention. You do NOT need a tractor to get a Class A CDL, you need the right combination of vehicle to classify. Tractor, box truck, flat bed, etc.
    If you tested the M2 sport chasis by itself, you'd probably get a Class B or C license. How ever, since the GVWR is 19k, you would probably get a Class C license. Remember, when you bring a 10k vehicle that turns into a class A combination.
    BOTTOM LINE, if you need a Class A to operate an M2 sport chasis and a trailer with a GVWR of 10k or more, than you should be able to take your road test in it.
    I think what is happening, which I don't blame them, they don't want you to take the test in this dinky little truck and then be able to go out and drive the big rigs. But, from a legal stand point, I think they are wrong. BUT, they gave you the restrictions for non air brake vehicle anyways. I'd just find another office to go to, then go back and rub it in their face that you got your Class A.
    You need to find out what the Georgia definitions are for tractor trailer combination. Maybe we are missing something. It sounds like they are pulling stuff out of the air and they can't back it up. Typical.
  5. smbartl5
    Haha, I like my "dinky" truck! I don't plan on running any big rig, this is the biggest I'll be using (It's all I need for towing a 2 car aluminum trailer to race tracks around the country).
    Yeah, that has been the hard part - obtaining the definitions of the tractor trailer for the State of Georgia, and getting anything in writing from them to support what they are saying. The first lady I talked to on the phone said it's not a tractor because it doesn't have air brakes and isn't manual, then I asked her where she got that info and I cited the US DOT definition, and she had no response and just told me to go to the DDS office.
    The DDS office is consulting the person who oversees all CDL licensing for clarification, as well as speaking with MCCD.
    And just for clarification, I did receive my Class A - just with an "O", "L" and "E" restriction.
  6. jsprocket
    jsprocket Heavy Load Member
    830
    262
    Nov 4, 2013
    Columbus, GA
    The heck you take it at
  7. jsprocket
    830
    262
    Nov 4, 2013
    Columbus, GA
    Must be an east Georgian, them east side Georgia people are screwballs, west Georgia where it's at except them dang alabamians.
  8. smbartl5
    Took it at Milledgeville
  9. Eric1234
    Eric1234 Bobtail Member
  10. Eric1234
    It seems that non CDL service centers aren't aware of CDL rules. Just got home from Georgia where my student wasn't allowed to test in the tractor (manual) and trailer we brought because he had an O restriction on license. O restriction has to do with coupling system i.e. hook and eye verses having a fifth wheel. Tennessee refers to this as a 57 restriction. Hope this helps
  11. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Hopefully he figured it out 6 years ago.....
    snowwy Thanks this.
