So there is a very reputable CB guy around here that runs a little shop. It's not one of those just off the interstate kinda deals where they will screw guys passing through. This guy only serves the local truckers in the area.
So a buddy of mine talked me into buying the General Lee radio with the amp on the bottom that is supposed to be pushing 100W and whatnot. This guy also tunes and peaks all radios before he puts them on his shelf for sale. My truck is a 2000 KW W900L and I'm sure needed a new coax. We ran a new coax that evening and then ran 10 gauge wire to the battery box. I just had a few questions for all of you CB savvy guys.
- Mr. CB Man told me that with this radio, I had to run it directly to the batteries. Does it matter which battery in sequence? I always park the truck with the radio, CB, etc. turned off (I won't leave a phone charger plugged in or anything). Will this cause one battery to go bad before the rest? Is there any better way to wire it up with a big radio pushing this much power?
- I mostly do work for the coal mines hauling their big longwall equipment. There hasn't been much work so I've just been running my triaxle hauling dirt. I really haven't gotten to try the radio out yet. What sort of range should I expect from this? I know that your antenna plays a great deal into the whole unit and I can't remember the exact antenna I put on that truck a few months ago but it's a whip style antenna. Probably 4-5' in length and is on top of the mirror bracket.
- I didn't realize how many options there were to coax cables until I was looking through other articles here. I would assume the coax I bought should be good enough. He is a pretty knowledgeable guy.
Is there anything I could change or anything you would do differently to get better results? I'm really not great with this CB stuff but I would like to be. There is so much knowledge on the internet that it is overwhelming and hard to sort through. Any input is appreciated!
General Lee 100W Radio
Discussion in 'CB Radio Forum' started by DaltonR121, Nov 18, 2013.
I really don't believe that it matters, which battery you hook it to. I might have dropped down to a size 6 or a size 4 wire for my power wire from the battery. You'll know for sure if you have a big enough power wire. If you key up the radio at it's highest power setting and it dims it not getting enough power. Also put a fuse as close to the battery end of the cable as possible. I believe it will be about a fifty amp. Just open the fuse holder, the bayonet fuse will be in there.
As for range depends on your swr, antenna, terrain. Just let your cb guy check your swr and impedance.DaltonR121 Thanks this. -
What do you mean by which battery in sequence? Does the truck have more than 1 battery?
Basically, you run the red wire on the radio straight to the battery positive and then you run the black wire on the radio to the batterie's negative, or to a good clean ground on the truck, provided theres a good clean ground from the battery to the truck.
You pretty much answered your own question on the range, but to be honest it's difficult to tell you what range the radio will have as there's many factors besides just the antenna. I would say it's safe to say, provided skip isn't rolling (such as it has been latelly), 5-10 miles is doable....however if skip is really going, you might not be heard 2 miles up the road.....yet you might be heard 200 miles away.
Good coax for CB is RG8X, Belden 9913, LMR400 (overkill on a truck but #### good), LMR-240, etc.
For best results get the SWR as low as you can, if possible put the antenna dead center of the truck (might be hard to do) and run the best antenna you can. I like whip style antennas over coiled glass antennas. I often recommend Wilson 2k trucker antennas for semis. If this were a personal vehicle, I'd say a Wilson 1k or a 102 whip. -
