General: Cummins VT 903
Discussion in 'Trucks [ Eighteen Wheelers ]' started by barroll, Jan 28, 2012.
  1. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    I've searched this forum, and a dozen others, and all I seem to find on this engine are complaints, annecdotes, and unrealistic numbers concerning a good buddy's souped up tractor with a 9-0-nothing.
    I've expanded my search into the V 903, VTA 903, and V/VT 903M, and not found much more beyond stories of shimming the fuel pump, and how loud they can be.
    Any more general info on this engine? I've read that 700 hours is a good interval for setting the valve lash clearance, but that's about all.
    Are there still any decent mechanical fuel pump shops around? I'd like to have mine gone through to get the seals and O-rings changed out for neoprene so I don't run into issues with biodiesel. $300 is what I've read for a tear down, and it sounds like money well spent to me, but I don't know where to take it.
    Are there any big reasons I shouldn't consider having the springs and shims played with on the pump while its off the truck, other than premature driveline wear? I'm not looking to hoon around at 80mph in my large car, but I've read they do a bit better on the hills with the extra power, and they can do a bit better on fuel if you keep out of it. Should I just go straight for the 600HP setting, or are the intermediate settings that would be advisable?
    Thanks in advance for your time to anyone that still knows anything about these engines.
  3. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    I have done some 903 work years ago. It's not an engine you see too often. I would set the overhead at around 60-70k miles or around 1500 hrs. That is a good overhead set interval for any mechanical cummins. Parts for this engine can be very expensive so I would avoid cranking the fuel too much. It's tough to find any fuel shop that will turn the fuel up beyond what the pump code calls for. All you can do is ask them to adjust to the high side of the spec.
    Before you go turning it up go over all the basics first. throttle linkage full travel, fuel filter, afc diaphram, boost leaks & overhead settings.
    barroll Thanks this.
  4. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    The truck only has 17,000 miles on an in frame, so hopefully I shouldn't be too far off from being able to think about turning it up.
    Does the standard shop manual cover the overhead settings? I've seen clearances vary from person to person.
    Also, would it be unwise to add a secondary fuel filter? I've never felt comfortable with less than 2 filters going into a mechanical pump, and prefer having at least one on the return line. How much do I need to worry about backpressure/low pressure with these large pumps?
  5. pup
    252
    256
    Dec 3, 2011
    n.h.
    Check the engine data tag for valve lash & injector travel specs. Newer engines had more info on the tag than older ones. At 17k the engine shouldn't really need the top end set. Does the engine have a smoke or misfire problem?
    The shop manual should give you what you need.
    There are 2 different methods for setting the injectors, inner or outer base. 2 very different procedures.
    A good spin on filter is fine for that engine. Fleetguard fs1000 would be fine. You dont need 2 filters.
  6. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Oddly enough, this is the only VT 903 I've ever heard of that doesn't smoke. I haven't gotten to take it uphill under a load yet, but haven't seen a puff of it at startup, idle, or running around bobtail.
    The injectors were replaced 17k miles ago as well. Think they'll need to be set soon? I read something in a marine engine forum about "rotating the injector bodies 30 degrees". Does that make any sense?
    Is the V/VT/VTA 903 sometimes referred to as the 903C? That's the only digital manual I've found outside of austrailia. It covers a few old cummins engines, and has about a hundred pages covering the fuel pump that's used in the VT 903, but no mention of the VT 903 itself, just a "903C" V8.
  7. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    The general rule on a mechanical Cummins engine is to index the injector intake screen toward either the intake side or the exhaust side. This orientation of installation keeps any debris coming into the fuel rail from collecting on the injector intake screen. The debris will wash on by and return to the tank.
  8. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    That just makes it seem like a return line filter would be even more worthwhile.
    I've read that backpressure on the fuel return line can cause some sort of mayhem in older engines, though.
  9. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Restriction on the return would raise rail pressure and could cause engine to surge/hang on deccel and hunt at idle. The proper orientation of the injector at installation is sufficient.
  10. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Diesel Fuel Injection service Inc
    9331 South Broadway
    St Louis Mo 63125-1603
    314-631-2500
  11. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Thanks. They aren't too far from home either. Just got a digital army/air force technical manual for the fuel pump and injectors, and it looks like it isn't too bad to field service. I'd still like to get the machining and seals done right before I get a chance to play with it on my own.
    bender Thanks this.
