I am using this gearbox in my truck
And manual said below:
Which gearbox oil should I use?
Gearbox oil?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by eng.moh.4u, Apr 1, 2017.
But the manual said PS-321 and this type is not here in Saudi Arabia -
I've always used 50wt mineral oil in all my transmissions. Synthetic if available.
Roger McG Thanks this. -
PS-321 was an old spec (non-synthetic I believe) that was replaced by PS-386, which is a synthetic SAE 50. We use Castrol CD50, but any major brand has its equivalent.
A synthetic SAE 50 should be fine for you. But if you can't get synthetic, I'd find out if they recommend a higher viscosity for your hotter weather in Saudi Arabia.SAR Thanks this. -
https://www.google.ca/url?sa=t&rct=...Dpps7Zd9UWn0aroKw&sig2=cYnTBOGhmole43GNGfgsLQ
Eaton approved lubricant supplier list.Ezrider_48501 and SAR Thank this. -
sae 50w synthetic is what i have always used in all Eaton manual transmissions.
Same here. I have used 50w synthetic for a long, long time.
