Gauges backlight stopped working
Discussion in 'Ask An Owner Operator' started by Flatbedotr, Sep 30, 2023.
  1. Flatbedotr
    Flatbedotr Light Load Member
    100
    35
    Nov 26, 2018
    Hello,
    Was wondering if anyone can help with this issue. The backlight of my dash gauges (speedometer, air brake, etc) is currently not working. Other lights (like the AC cluster, the 5th wheel slide, and the air dump) are working, however. Looked at the fuse panel diagram, and thought it was C10, but that fuse is good. Does anyone know what fuse controls the gauges backlight in a Peterbuilt 579, made in 2020? Thanks for any help!
  3. skallagrime
    skallagrime Road Train Member
    3,836
    9,880
    Apr 10, 2012
    Indiana
    While i dont know that truck, i would lean towards that gauge cluster just having a broken or loose or disconnected positive. Pretty sure if you have backlight on all the rest, it shouldnt be a fuse
  4. 062
    062 Road Train Member
    6,143
    33,182
    Oct 20, 2013
    It may be controlled by a module.
    You can try unhooking the batteries,then after hooking them back up do a few key cycles without starting.
    Sometimes if you don’t allow all the modules to communicate before starting the truck,then you may have problems.
    @Goodysnap
    Oxbow and Flat Earth Trucker Thank this.
  5. Espressolane
    17,001
    102,598
    Both KW and Petes have this problem.
    It is not a fuse. It is a combination of the ignition switch and the body computer.
    With the truck OFF, work the ignition switch several times. Basically wiggle it. Sometimes after the ignition switch is shut off for a while, it will start working again. Sounds goofy but it is what it is.
    Vampire, Rickp and Oxbow Thank this.
  6. Flatbedotr
    100
    35
    Nov 26, 2018
    Yup yup, just needed a restart like my phone or computer and cleared it up, thanks for assist guys.
    Long FLD and Oxbow Thank this.
  7. Long FLD
    Long FLD Road Train Member
    11,380
    45,925
    Mar 4, 2015
    Don’t turn the key and fast start it. Give it a few seconds after you turn the key to let the ABS cycle and let all the modules start booting up before you start the truck.
    Vampire and Oxbow Thank this.
