Gates or Dayco Belt tensioners, anyone familiar with them?
Discussion in 'Ask An Owner Operator' started by Derailed, Oct 13, 2018.
  1. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Just curious, Anyone have any bad experiences with the aftermarket Gates or Dayco belt tensioners? Gates ones look pretty good. Made in Canada supposedly. About half the price of the Cat ones.
    jamespmack Thanks this.
  3. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    Gates makes great belts, in pretty sure their hardware is just as good
    jamespmack and Derailed Thank this.
  4. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Gates does have a good name. I almost wouldn’t even consider them aftermarket.
  5. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Caterpillar doesn't make their own belt tensioners, they contract them out to the lowest bidder to make them, and than put them in a Caterpillar box and mark the price up 200%.
  6. Opendeckin
    Opendeckin Medium Load Member
    446
    1,241
    May 20, 2018
    Same deal on the air compressors. They contract bendix to make their air compressors.
    Cat air compressor $1200
    Bendix air compressor $363
    Caterpillar has really gone down the hole. I'm considering going aftermarket for most of the components for my next 3406E overhaul.
    jamespmack, Derailed and boneebone Thank this.
  7. Derailed
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Thanks, I was kind of suspecting this was the case but wasn't positive. Always had good luck with gates hd belts..I knew the air compressors were Bendix.
  8. Ridgeline
    22,112
    113,286
    It isn't always the lowest bidder, cat like cummins uses either Dayco or AJ Rose for their parts.
    They set the OEM price, then there is a release for aftermarket sales, which is based on the OEM price.
    Mark up from the dealer is based on their replacement/warranty costs, not the aftermarket pricing.
    Get dayco or Gates, they come from one or another manufacturer, Dayco or Rose.
  9. Rideandrepair
    17,214
    55,886
    Aug 8, 2015
    Or just buy new bearings if that’s all you need very cheap
  10. Derailed
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    That was my plan. I picked up a few bearings along with the serpentine belts. Got looking at the tensioners and I'm thinking the pivot bushing is going in one of them. Looks slightly tweaked. Belt has a slight squeal to it. Everything spins fine with the belts off but I'm just going to replace everything and be done with it
    Tug Toy and Rideandrepair Thank this.
  11. Rideandrepair
    17,214
    55,886
    Aug 8, 2015
    I did the same kept old one for back up
    Tug Toy and Derailed Thank this.
