Hello Drivers! I'm in need of advice what to do if I got gasoline instead of diesel at Pilot truck stop in Belgrade, Mt on December 5 2017 around 6:30 pm. Please keep in mind it was disel island. Not my mess up. My truck currently in the freightliner shop being evaluated for damages.
Gasoline in diesel tank
Discussion in 'Experienced Truckers' Advice' started by Trav007, Dec 8, 2017.
Page 1 of 5
Gas and diesel is a highly explosive mix, have them clean all that completely out including fuel lines and filters or make sure your insurance is paid up and to the max. Hopefully it was the truck stops mistake because it can get very costly, but them 2 fuel mixed makes a static charge that might be ok as long as everything is completely full, get down to fumes you will be in trouble.
Lepton1 Thanks this. -
Currently we looking at much bigger repair, truck drove closer to 400 miles on gasoline/ diesel mixture , according to freightliner flashing out sistem won't cut it.... Im looking for victims like me who got fuel at this truck stop
You positive you were not at the gas pump? Which pump were you on? I ask because the first island does have gasoline, the one closest to the building.
Oxbow and Oldironfan Thank this. -
Didn't the nozzle look different to you? Did the pump say diesel?
Honestly if so it's pilots bill.
Only thing I see getting ruined would be injectors. It will not damage much else. Gas can be mixed at 10% with diesel.Grubby Thanks this. -
You got double posts running.
Did you get diesel in Belgrade, mt at pilot on December 5 2017 -
That truck is a sad sack on that mix. We have lost entire engines on that screw up before. Never me personally but companies have suffered losses with that.
I for one cannot understand how a diesel fuel pump can supply gasoline, if that is the case then the Pilot has to pay and HOW.... bill em or sue em.
If you drove with that gasoline in the fuel tank, you are riding on a bomb. Consider today your new birthday because if it ever heated to a certain flash point you would be cremated the hard way.Lepton1 Thanks this. -
x1Heavy Thanks this.
You did not notice the smell difference or the off color of diesel?
Steel Dragon Thanks this. -
Steel Dragon, NavigatorWife and x1Heavy Thank this.
Page 1 of 5
