Gas pedal vibration
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Highwolf89, Oct 14, 2014.
  1. Highwolf89
    Highwolf89 Light Load Member
    294
    61
    Jul 30, 2013
    I have a 96 kenworth t600 and it seems like my gas pedal gas vibration and it really irritates me and makes my leg hurt sometimes from the vibration what could be causing it.... And is there a way to dampen the vibration...
    thank you
  3. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    What engine? If it's a non-electronic then you have a direct link to the engine under your foot, and any lack of smoothness in how it runs will be telegraphed back to you. It may just need the injectors and valves gone through.
  4. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Seriously???? Let me go put my waders on I will be back later to read the replies on this one.
    snowblind and Shaggy Thank this.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Sounds like a spark plug or maybe carb is out of adjustment. Ps maybe try a cushion type shoe
    postmandav and Shaggy Thank this.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Get those gel inserts for your shoes...
  7. pupeperson
    pupeperson Light Load Member
    216
    203
    Jun 9, 2013
    You don't really say what kind of vibration it is, or under what conditions it manifests itself, but one possibility is worn out or broken motor or transmission mounts.
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    worn engine/tranny mounts.
  9. Shaggy
    Shaggy Road Train Member
    3,116
    2,599
    Sep 21, 2006
    FIGMO
    Using a few gallons of diesel can make a slight improvement, Check the Owners Manual for the GAS/FUEL ratio.
  10. Highwolf89
    294
    61
    Jul 30, 2013
    I think it's my mounts I am going to have all my mounts changed... It's s cat 3406e...
