Gas or hydraulic which is better?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by T800H, May 18, 2012.
  1. T800H
    T800H Medium Load Member
    608
    298
    Apr 2, 2010
    The Keys
    Shock absorbers gas or hydraulics which is better for air ride and why?
    I have always like the hydraulics better than gas but the last two sets that I've got you could push it in with no back pressure at all, it was to pull it out that it required a lot of power, it seemed to me that when the tire bounced it will go up automatically and that's when it need the shock absorber to produced some back pressure not when it's going back down.
  3. T800H
    608
    298
    Apr 2, 2010
    The Keys
    anybody?
    Bump.
  4. aktundratugger
    aktundratugger Light Load Member
    126
    32
    Feb 10, 2012
    up on the hill, Ak
    think of a basketball, if you don't force it back to the ground then it does not bounce. same with tire. catch the force and dont let it return to bounce again.
  5. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    A 50/50 hydraulic shock does a good job of dampening a rough road, however a gas charged shock is better at keeping the tire in contact with the road surface for better vehicle control. Todays technology focuses on the latter. If you prefer hydraulic over gas you could shop for 50/50 hydraulic shocks instead of just taking what they have to offer. I'm not familiar with other hydraulic shock ratios other than 50/50 for a truck or the reasoning behind them.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    gas shoks loose gas in 1-2 years and run worse hydrolic but do not leak.
    So with gas shoks you need to check it on vibro tester every year to find bad one.
    Bad hydrolic shok leaks oil
  7. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    gas charged shocks are designed to not fade as fast on bumpy roads. They help prevent the oil from foaming. Once you loose the gas in the shock, they fade quickly.
    Shocks have a service life too. Can's say how long depends on your driving area.
  8. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    Yep, winter roads here are so rought and it is additional stress when shoks are cold. May be that's why we have to change shoks every two years.
  9. T800H
    608
    298
    Apr 2, 2010
    The Keys
    Thaks every one for your imput, I don't mind replacing shocks every year, so if gas are better but their life span is about two years, I think I'll go back to them and just raplace'em every time I get new tires, which is about once a year.
