Gas mileage
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by dnice2136, Jul 25, 2020.
  1. dnice2136
    dnice2136 Bobtail Member
    I have a 26ft FreightLiner with a Cummings ibs engine and 100 gallon tank. How many miles can I drive on both tanks being full.
  3. Grouch
    Grouch Road Train Member
    2,079
    4,243
    Feb 3, 2009
    Between here and eternity
    Many factors figure into this. But a "ball park" answer is 500 miles and this is a conservative answer. You might do better. Why don't you go and fill it up, load the truck with the typical load that you will be hauling, run 300 miles, stop, fill it up again and get your calculator out and figure the mileage. Bingo, you got it!!
    tscottme, Speed_Drums and dnice2136 Thank this.
  4. 201
    201 Road Train Member
    12,047
    24,587
    Apr 16, 2014
    high plains colorado
    Hi dnice( Denise?) Sounds like a rental truck, and has 2-50 gallon tanks( I doubt 2-100's) No fuel gauge? Since it's a small truck, it will get better than a semi, which average about 7-8 mpg. I doubt you'd get 10mpg, but use 8 to be safe. I'd say, at around 700 miles, I'd start looking.
    dnice2136 Thanks this.
  5. AModelCat
    154,272
    Nobody can give you anything other than a very vague estimate. Way, WAY too many factors in determining fuel economy.
  6. Allow Me.
    10,642
    12,100
    May 28, 2009
    Rancho Mirage, Ca.
    Hi Dnice......So, in trucking, it's refered to "fuel" not gas, and it's a "Cummins" engine, not a "Cummings". So I would guess you have a 26 ' straight truck which will probably get around 8-9 mpg. Are you new to the Biz ? Don't be a stranger !
  7. 201
    12,047
    24,587
    Apr 16, 2014
    Don't make them feel bad, as an old timer, I grew up thinking, there's nothing wrong with calling a Cummins a Cummings. Columbus vibrator too,,:biggrin_25514:
    Mohtrucker Thanks this.
