Garmin OTR-800 stuck on "Dancing Triangle (pyramid?) Screen"
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Hornswoggled, Oct 12, 2023.
  1. Hornswoggled
    Hornswoggled Light Load Member
    74
    44
    Jul 25, 2014
    Florida
    I've had an OTR-800 Trucking GPS for a few years now. I keep it updated regularly. I've had problems for the last year or more, especially at boot-up.
    The unit boots up and defaults to a car profile. When I change it to one of the three profiles I created and use (Bobtail, 53' trailer, or pups), it goes to the dancing triangle screen, and stays there for an excessive amount of time. Just to see, one time I let it go on for over 40 minutes in this state. Most times it will eventually come out of this screen and be ready to use. But it can go on for long periods.
    Sometimes a reboot or two will resolve this. It seems to be particularly successful if during the reboot, it goes back to where the black & white picture screen appears during boot-up (a picture of a tractor-trailer.)
    Most of the time, this problem is confined to changing the profile at startup. But I have had occasions where it has gone into the dancing triangle spontaneously while driving. When that happens, suddenly I have lost all directions. While most of the time that wouldn't be a problem -being on the open road- I had it occur last month while I was driving in the L.A.- Ontario area, going to a new location I had never been to before. A mile or two before taking an exit, I lost all guidance. I had to blow past the exit a few miles until I could find a safe place to pull over, and recover the GPS.
    Any ideas on what is going on here, and how to resolve it?
  3. SomeCanadian
    SomeCanadian Light Load Member
    151
    415
    Nov 11, 2021
    I’ve never seen the exact conditions you describe but I would check for route restrictions (ie you told it not to use that road, even if it’s on the other side of the country it slows route calculations) or I would give it a little bit less info about your truck in the profile (probably delete them and try just a generic truck profile).
    My older model started having problems when my battery no longer held a charge. But it also started overheating in freezing weather if it was in direct sunlight.
    Other than that if you got three years out of it then it was a little short but it might be time to replace it. Or find a place that can/diy do a good internal cleaning and thermal paste/pad replacement.
    Could also try forcing an older version onto it.
    What did tech support say when you called?
