Garmin Dezl 770 and IFTA
Discussion in 'Trucker Taxes and Truck Financing' started by CharlieK, Apr 6, 2017.
  1. CharlieK
    CharlieK Medium Load Member
    374
    4,454
    May 13, 2015
    Minnesota
    Those of you using the Garmin Dezl 770 or equivalent for tracking your IFTA, how do you print out your trip reports? Or do you?
    I'm not asking how to export the data, to me, that's the simple part. The summary is all you need to complete the IFTA filing, and that easily fits on a page of paper. The trip report however, is multiple page, over width, and over height! Need to flag the darned thing!
    Before I was using the Garmin for IFTA, I was filling out trip reports. I'm not sure how others do it, but my trip report was per tank of fuel, and being a local to regional driver, it just... made sense. When it came time to file IFTA, each trip report had a fuel receipt stapled to it, they were stacked up, with a copy of the IFTA filing on top, all stapled or paper clipped into a nice neat bundle, and into a file folder to show an auditor if that ever came to be.
    With the way the Garmin Dezl exports to the spreadsheet, its not really something that can be printed out worth a darn unless you do a lot of editing? This goes along with my assumption, that everyone DOES keep hard copies of trip reports, and not just in a file on the computer. Do you edit the heck out of it to print it so it makes sense looking at it? I'm far from a genius running a computer, do I just have formatting messed up? Settings somewhere to adjust?
    This whole book I just wrote, is just to ask the simple question, "How do you print your trip reports" to keep hard copies.... Or.... do you?
  3. DoneYourWay
    DoneYourWay Light Load Member
    186
    198
    Aug 10, 2013
    one of 48
  4. CharlieK
    374
    4,454
    May 13, 2015
    Minnesota
    No, my problem isn't with the exporting. Unless I'm really missing something, there is no way to save the file differently. The problem is, when the trip report is exported, and then opened in Excel, the field that contains the road numbers, lists all roads, which means that it can get to be a very, very long field. That field, stretches way off the page, even printed landscape, can be several pages long.
    There may be a way to configure the field in Excel so it continues to the next row after it gets to a certain length of cell? But, if there is, I have no idea how. I guess I should be calling in the help of one of my teenagers for that.
    The summary page, loads in a nice condensed way, that makes it very nice for using/getting the information needed to complete an IFTA filing.
    All of this may be immaterial however. The folks that I was just talking to think that if I was to have an IFTA audit, to have those files on the computer would be just fine. I have always looked at it as needing to have a paper/hard copy. If this is the case, then there is no reason to print them out, and then none of this matters.
    DoneYourWay Thanks this.
  5. redoctober83
    redoctober83 Road Train Member
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    In excel it's called wrap text. That's the formating option you are looking for.
    Here is a tutorial on how to use the function http://study.com/academy/lesson/wrapping-text-in-excel-how-to-wrap-text-within-cells.html
    Hope this helps.
  6. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    So double checked the CSV file extension and Excel is a common reader for that... But for some reason what is happening is your losing some of the formatting of the document... Try updating Excel or if you have a very old version get a newer copy or try a free .CSV reader (Google it)
    Unfortunately Excel documents and the like are not my specialty when it comes to computers more of a hardware and diagnostics guy rather than secretarial type programs.... But the above would be my first guess as to why it's running off the page
  7. Aradrox
    900
    622
    Jan 21, 2016
  8. redoctober83
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    Not in a csv file. There is no formating at all in that for type.
  9. Aradrox
    900
    622
    Jan 21, 2016
    I see well that just means some programmers need to update the python language to allow for formatting in a CSV file
  10. Ridgeline
    22,114
    113,324
    Charlie, I wonder if you know that you can do a couple tricks to see the info, one is to save the file in excel format (.xls) and then reopen it up and adjust the column width. I don't know if this would work for printing but it may help to see the needed data.
    If you need it split apart, then that's a bit more complicated to do and very hard to explain on a forum.
    wis bang and CharlieK Thank this.
  11. redoctober83
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    By definition a csv file is suppose to be formatting free that way the data can be imported easily into other programs, databases, etc. That's why csv files can even be opened in notepad and other word processing programs.
    CharlieK Thanks this.
