"Galloping," or speed related "hopping".
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by W900AOwner, Jun 27, 2017.
  1. W900AOwner
    W900AOwner Heavy Load Member
    714
    1,284
    Jul 2, 2014
    I usually wouldn't come to a forum to ask certain question pertaining to this, as I consider myself pretty informed in trucks and mechanical problems over the years. But I have this '78 Kenworth I just rebuilt over the winter of 2016-2017 and I have a speed related gallop in the truck that's about to drive me insane.
    I highly doubt it's driveline/shaft related. It's a speed sensitive "hop" that comes and goes at a couple of particular speed ranges that are unfortunately the ones that I use frequently of course. The first place I looked was at the tires. (You always wanna start on the easier stuff.) The best description of it would be a tire that feels egg shaped.
    It had 8 new virgin drives on it when I bought it, although I know that means NOTHING these days; a lot of tires aren't round as they used to be. But I swapped the tires off the truck from my other truck that goes down the road like a champ, and didn't seem to change the problem. So yesterday, I swapped the tires all back original again. I also played around with the ride height yesterday. It's old school KW 8 air bag suspension that I totally rebuilt and rebushed except for changing shocks which are new from the seller. I dropped the height considerably, about 1.5" by changing the bolt hole that the link is in on the axle housing, and I measured 9.25" to 9.5" from bottom of frame rail to center of axle housing (weld seam.) It was previously at 10+"...
    I checked every inch of driveline, and with the exception of a loose input shaft bearing on the forward rear, everything's tight. It doesn't even vibrate (yet), but I'll address that this weekend anyways before that gets worse. (The problem isn't a vibration, for those of us that understand the difference between a hop/gallop and a vibration.)
    Other than to keep digging into this deal, I was just throwing it out there to see if anyone's had this go on before...I'm sure many have. It's rotational-directional, so my guess would be a brake drum next, so that's how I'm leaning. Out of balance drums will do this exact thing.
    I spent $300 bucks 2 weeks ago at a KW dealership in Connecticut to run a dyno test, but they didn't let me in the bay to observe anything, so that was a serious waste of time and money. Maybe I should get it in my buddy's shop, jack it up off the floor and run it and see what I can or can't see...
    It's one of those deals that will drive you crazy.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    It is common to have wheels that do not self center on hubs or hubs that are not machined to center a wheel on it, and therefore the wheel itself is running out of round causing your gallop. Best way to find it is putting both drives up on jack stands and running the truck at about 30 mph or so and watch for the tire that is going up and down as it is spinning. This is sorta tricky, if you spin them too fast, they are just a blur and will look perfect, but too slow and you can't pick up the osculation either. We use extreme caution with this test, always have a second person in the cab with the steers tires fully blocked and all stones picked out and keep away from spinning parts. Be safe if you perform this test.
    Dennytech1, KB3MMX and Grubby Thank this.
  4. AModelCat
    154,260
    Are the driveshafts phased properly? The yokes on either end of each shaft should be aligned to each other.
    I have had a bad u-joint feel like a hop, almost like someone was kicking the bottom of the seat at the exact same speed every time. That was on a half ton truck mind you but I'm sure the principal would apply to a large truck as well.
  5. Autohauler13
    Autohauler13 Bobtail Member
    May 30, 2017
    That sounds like a horribly dangerous test Heavyd.... Maybe he could just block the wheels, jack the truck up, release the maxi brakes, put a jack stand next to the wheel about a 1/2“ or so away from the tread and the spin it by hand, that should be plenty to tell him if it's out of round. Just a thought!!!
  6. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yes, it is very dangerous and that is why it needs to be done properly and safely. But you would be shocked at how little a tires need to be running out of round to cause a major shake. You'll never see it turning it by hand.
  7. Autohauler13
    May 30, 2017
    I think you would definitely see it if you put a jack stand next to the tread so that you have a reference point. Probably not if you're just looking at it without anything there
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    I have found problems like that just as HD. Did not run them quite that fast. Tightening the steer axle brakes all the way down helps with stability. Lock the P/D.
    Reminds me of two cases. First had out of ballance drums. They had no external ballance weights to stop them when rolled on the floor. Rolled a few rotations, stoped and came back, then reversed again. Second was a off center hub.
  9. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Easy rule of thumb to check ride height on KW Ag100 air ride. Slide a 2x4 between the axle stop and the top of the axle. It should just fit.
    BoxCarKidd Thanks this.
  10. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    Check to see if you have the right brake drums installed, if the drums are not piloting up correctly they will throw out the wheel balance.
    I had this happen once on one axle, I had the brakes replaced and both drums but they installed the wrong drums and it hopped at 30 and 60 so bad I was sure it would break something if I put a load on it.
  11. LoudOne
    LoudOne Medium Load Member
    30 mph on jack stands?
    Please let us know where your workshop is.... So we never come near it...
    That's dangerous all hell...
    ExOTR and p608 Thank this.
