Does anyone know the location of the relay box on a 98 kw w900? Me and my mechanic are trying to locate the relay for my engine fan and it's not located in the fuse panel thats by the clutch pedal.
Or does anyone know the location of the engine fan relay?
Fuse/relay panel location 98 kw w900l
Discussion in 'Kenworth Forum' started by irishluck09, May 14, 2022.
Open the gauge panel and switch panel to the right of your speedometer. The engine fan relay is in there. You will have to dig around to find it , not mounted , it just lays in there towards the bottom.
spsauerland, Oxbow and ProfessionalNoticer Thank this. -
Fire your "mechanic".
Opendeckin and spsauerland Thank this.
Even with multiple phone calls to MHC kenworth, they didnt even know where it was located -
remove the panels to the right of those , temp gauge panel and the switch panel next to it. Trust me the relay is there , it will be buried under a lot of air lines and wires
spsauerland Thanks this. -
WIll report back tomorrow. Thanks -
The diagram of the harness is no longer available K068-6648, but relay is part of the Cummins in cab harness. The fuse panel was designed before electronic engines, so add on harness were used for Cat, Cummins, or Detroit engines. I attached the diagram in your other thread. The diagrams calls out the wire #, color, and gauge. Find it that way. Most likely stuffed in behind gauges somewhere, been along time since I worked on one with a Cummins.
ProfessionalNoticer, kranky1 and Oxbow Thank this.
