Fuse box location on 2006 379X
Discussion in 'Peterbilt Forum' started by Jerms1973, Feb 24, 2016.
  1. Jerms1973
    Jerms1973 Bobtail Member
    Is there a fuse panel on the driver side firewall in engine compartment? I was told there was but can't find. I think the fuse for my interior sleeper lights and fridge is in there. I'm gettin hungry!
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,646
    15,948
    Jan 18, 2011
    haven't been in one w/the last model interior......late 05...up....but unless they changed more than the dash&mirrors for the 1st time in near 20 yrs.....there should be an access door...by your left foot....right as the lower fire wall starts to angle back towards the drivers door
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    In 2006 you have the normal fuse panel by the clutch pedal and a separate one for the sleeper. The sleeper panel is accesses through the left side door, it mounted on the drivers side front wall under the bed.
    You also have relays behind the speedo/tach cluster. The cover of the panel by the clutch pedal shows you what's behind the speedo.
    I have never seen a 379 with a fuse panel under the hood. All of our newer 388/389's do, but not the 379's.
  5. Gearjammer122
    Gearjammer122 Bobtail Member
    Where are the fuse boxes on a 2003 peterbilt located. Was told there was one under sleeper bed but haven't located it yet
  6. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    One in the kick panel by your lh foot. One located in the sleeper, accessed from the jockey box. If you have a short bunk it may not have the sleeper fuse panel
    spsauerland Thanks this.
  7. Krzik
    Krzik Bobtail Member
    Does anyone here know where the marker light fuse is located on a 2001 378 ???? I was putting some custom mudflap lights on and i shorted out my marker lights , they all stoped working on the whole truck and i can not locate the fuse for the marker lights
  8. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    Shaking my head at you guys not knowing where the simple things on your trucks at. Trucking has surely changed
