Full CDL-A Pre trip checklist
Discussion in 'Questions From New Drivers' started by slw206, Dec 21, 2015.
  1. slw206
    slw206 Bobtail Member
    26
    6
    Dec 16, 2015
    Butler, Pa
    I am 1 week away from taking my CDL-A test. I would really like to pass all 3 sections on the 1st attempt.
    I am told the pretrip has around 120 possible points but only 70 is required to pass it. What i am looking for is a checklist that has all 120 or however many it is. That way me and my 2 fellow driving partners can practice. I live in PA and the Pre trip just changed about 2 weeks ago and is much more detailed. I am told it resembles what it was originally back in 1992 or whenever it started.
    If you know where i can find this checklist i would love a copy. I feel fairly confident in myself but having another aid to train me will only help.
  3. chris887
    chris887 Medium Load Member
    545
    421
    Nov 11, 2015
    chicago
    There are some training aides online, but there is not a universal checklist. Pre trip is specific to your truck and trailer. A lot of things are the same on all trucks and trailers, but there are also a lot of differances, not all have exactly the same parts to check.
  4. chris887
    545
    421
    Nov 11, 2015
    chicago
    Also, what state?
  5. chris887
    545
    421
    Nov 11, 2015
    chicago
    There are a lot of youtube videos. When I took it a lot of the points were subjective to the testor, it was based on how well you explained things and if you said key phrases that they wanted to hear. It's not 120 differant things to check on the truck.
  6. foreverlearning
    foreverlearning Bobtail Member
    46
    48
    Nov 10, 2013
    CT
    When I did mine in CT in 2013 the inspector had me do the in cab, full brake test and once I started the walk around I made it to the tractor mudflap and he said ok good job. After the exam was complete I asked him why he stopped my walk around. He responded saying "you verbalized absolutely everything you were doing, were thorough, and named parts and pieces by name and weren't afraid to get under the hood and actually check the items you were talking about."
    My point is to know your parts, even those not specifically listed on your sheet, get in there and grab hold of them, show confidence in your knowledge, and verbalize everything you do even exiting the cab say "I am exiting the cab maintaining three points of contact".
    Remember the inspector may not have his eyes on you at all times so remember this quote "you may check a part but if you don't tell him you did it it may as well have never happened.
    Show confidence and be proud of the skills you have learned and the opportunity to showcase them.
    Oh also address the inspector respectfully saying sir or ma'am. A few students I tested with and observed were disrespectful to the inspector and it reflected in the assessment.
  7. GumboSnow
    GumboSnow Light Load Member
    53
    27
    Nov 7, 2015
    I have attached the one I used to study.
    The Professional One Thanks this.
  8. Clyde07
    Clyde07 Heavy Load Member
    809
    1,927
    May 28, 2013
    Just go to your nearest truckstop tomorrow morning and watch all the drivers waking up and performing their pre-trips. Write down what they are checking and that will give you at least 2 or 3 of the points you are looking for. Of course, the guys with coffee makers in their truck don't even have to get out to do their pre-trips though.
  9. Hick
    Hick Heavy Load Member
    928
    1,624
    Dec 4, 2014
    "These are the wheels. They all have air in them. At least 2 mirrors. All the lights work. Let's go."
    Easy.
    LuDiesel Thanks this.
  10. GiantBeard
    GiantBeard Medium Load Member
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    Lights, mirrors, engine components.
    Make sure you identify your air compressor, power steering pump, steering/gear box, water pump, and all the hoses related to them. Identify anything with a fluid that you can check.
    The O-ring on your fuel tank cap.
    Your driveshaft.
    The lights on the back of your tractor!
    Headlight fluid should always be full.
    Suspension, brakes, tires, wheels.
    Start with your shock absorbers, or air bags, and slowly work your way down, identifying each part.
    If it helps, get a long stick, and poke everything as you describe it to yourself. It's not enough to know what its called. You have to know what it looks like and where it is.
    Just walk around the truck several times. Identify everything you can see and touch.
    G13Tomcat Thanks this.
