Fueling reefer while reefer on?
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Jan 22, 2018.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    190
    59
    Apr 13, 2016
    I've heard not to leave a car running while fueling up. Is that the same when fueling up a reefer, should I cut the reefer off when fueling it up?
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,499
    Oct 22, 2016
    North Dakota, Eh?
    Won't hurt anything. Keep it running, especially if you have a sensitive load on. I wouldn't want to risk it not starting for whatever reason. Just my 2 cents.
    Brickwall, tscottme, buddyd157 and 7 others Thank this.
  4. EverywhereMan
    EverywhereMan Medium Load Member
    303
    391
    May 28, 2013
    The North
    Diesel isn't as volatile as gasoline. You're absolutely fine to leave the reefer running while fuelling.
    TravR1, Tb0n3, Bean Jr. and 2 others Thank this.
  5. BigBob410
    BigBob410 Road Train Member
    5,665
    74,100
    Feb 2, 2016
    Beirut on the Bay, MD.
    No spark plugs....you'll be alright leaving it running.
  6. Moose1958
    Moose1958 Road Train Member
    15,090
    33,171
    Dec 17, 2010
    Williesburg, Virignia
    As has been said, the reefer running will not cause anything but a mild shaking of the trailer. However if you are sensitive to this all it takes is a second to flip the master switch off. If your unit is a problem child you are going to know by the time you first fill it then you take it to thermal king to get fixed. Then just flip the master switch back on. Most units will keep the settings.
    Crude Truckin' and Jdm5jdm5 Thank this.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    The only time it might be an issue is if it is literally almost running on fumes. The agitation could introduce air or sediment into the fuel pickup system. But you should never run a tank below half IMHO so it should never be an issue.
    foggy, Jdm5jdm5 and ZVar Thank this.
  8. Crude Truckin'
    2,377
    6,499
    Oct 22, 2016
    North Dakota, Eh?
    I like to live life dangerously.......LOL!
  9. Moose1958
    15,090
    33,171
    Dec 17, 2010
    I'm going to quote that comment to amplify it. Most reefer tanks are small. If your pulling a -10 load in 100+ degree weather its going to suck up fuel very fast. The bottom of those tanks are full of trash and crap. If you run a reefer out of fuel it sometimes will quit before the tank actually empties. When this happens unless you are a mechanic and know how to do a fuel filter replacment you are going to have to get help. It is what it is. It don't matter how much starting fluid you use because the filter is clogged as is the fuel inlet going to it. Moral of the story? NEVER EVER ALLOW THAT TANK TO RUN OUT OF FUEL. Also measure the level by eyeballing it. NEVER trust those fuel gauges.
    Brickwall, foggy, Jdm5jdm5 and 2 others Thank this.
  10. TripleSix
    127,948
    Just thinking about fueling...(slight threadjack)
    Once upon a time, there were FULL SERVICE truckstops. Attendant at the fuel island would ask you how much. You walked inside, ordered 'the Special', called mama on the payphone, ate, paid for the fuel, tipped the attendant for fueling and washing your truck, and hammered out.
    "How much did the truck wash cost, Six?"
    It was free! The special and a beverage was $5! In fact, the most expensive part of the whole ordeal was the calling cards. I guess those really were the good Ol days.
    Man, you'd go driving along, and hear some sweet girl on the radio, telling you what the special was, how much fuel was, what exit they were at...etc. The thing I haven't figured out all of these years was who the heck was eating all of that banana banana banana pudding. Give me apple pie heated and a scoop of ice cream. Keep the baby food and wafers.
    Yeah, there were buffet joints, but I always liked the specials. 1 plate. That's enough. You can't expect to pig out and drive. Well, I couldn't.
    Toomanybikes, foggy, wore out and 2 others Thank this.
  11. TripleSix
    127,948
    I guess we all used to park on the fuel island...
