Fuel Water Separator Needed on Cummins ISX?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tallmon, Dec 18, 2015.
  1. tallmon
    tallmon Medium Load Member
    657
    319
    Oct 22, 2014
    So my 2007 KW T6 with Cummins ISX was originally spec'd with two fuel filters. Donaldson P552200 and P552203 (this is what the dealer tells me based on the VIN). I just noticed that the shop that's been doing my PM's for the last couple of years has been putting on a P552200 and a P551000. The second one is a fuel water separator.
    Is this a problem? What are the pros/cons to running with or without a water separator?
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    I would never run without one. There is no downside to not having water in fuel
  4. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    I noticed Paccar specing those exact filters and had more than one discussion with owners where the water goes. Having worked for CAT and Cummins I can assure you OEM's don't follow engine manufacturers recommendations to the letter. I would go to Fleetguard's site and check out filtration and flow specs and make your decision based on facts.
  5. tallmon
    657
    319
    Oct 22, 2014
    So are you recommending to go with the separator?
