Does anyone know what can be problem when fuel water separator filter is full after every 4000-5000 miles?
VOLVO 780 2016, D13, iShift.
Fuel water separator filter full after 4000 miles
Discussion in 'Volvo Forum' started by jaguar011, Dec 27, 2015.
BoxCarKidd Thanks this.
Bad fuel! I just spent four hours on one that made it 3 miles from the fuel stop. That's after a service call and a tow truck. When the tanks were drained it had mud? in the bottom of the tanks. If it is running that far you probably have it about worked out. Drain trash out of bottom of tanks after it has been parked and run a good fuel additive. Also maybe read up on post's about algae.
I just emptied mine. Davco 382 / D13 engine. Your supposed to drain that at least every other day ya know.
Last fuel stop was Petro OKC, 222 gallons.
I mean it is doing its job if its trapping the water.
Doesn't mean the filter is shot. Back in the day I was assigned a truck and the Davco kept clogging, and when dude pulled the old one off, it looked like the bottom 2 inches of the filter were turning into some form of cheese.Last edited: Dec 27, 2015
BoxCarKidd and mountaingote Thank this. -
mountaingote and Getsinyourblood Thank this.
I am not going to bash the folks that offered to pay all the expenses and closed the pump in Ga.
mountaingote Thanks this. -
BoxCarKidd and KB3MMX Thank this.
Yes,
Crappy quality fuel. -
One bad load is a gift that keeps on giving! If you buy fuel anywhere that just got a fuel drop everything in the bottom of their tank just got mixed up and you bought it. Thrash can also be passed down the line to them and you bought it.
In rural areas everyone does not have the options Dave mentioned but bad fuel finds its way to the big road as well. Suggest drain trash from bottom of seperator each morning intel clear
When you start pumping fuel look at it after a minute or two. Everything out of the silver nozzle is not gold.Dave_in_AZ and KB3MMX Thank this.
