I have a '05 Columbia with 100gl fuel tanks on each side, this is my first semi, should I be fueling the drivers side tank first or the passengers? does it even matter ? can I just fuel the same side tank every morning? I have noticed a fluctuating fuel needle while making sharp turns or going up hills? thanks
Fuel tanks
Discussion in 'Freightliner Forum' started by Ei, Sep 16, 2013.
Doesn't matter which you fill first. Whatever floats your boat. The fuel system will automatically siphon from one tank to the other if you only fill up one. For example, if you fill just one from 1/2 to full, and the other tank is still 1/2 full, the fuel will equalize in the tanks and show 3/4 full on your gauge. It's not instant, it takes a bit of time.
The fuel gauge will do that on hills and curves. There are no baffles in the tanks and the fuel sloshes around and moves the sender. Some trucks don't move so much because of some delay built into the system to avoid the wild gauge swings. My Pete fuel gauge stays pretty steady.luvtotruck Thanks this. -
And as i learned if one tank gats punctured you can cap off the bad one siphon the fuel to the good one and run off one tank but it sucks on a long heAvy run
One other thing on fuel gauges...my Volvo was an old...very old...Swift truck with 75 on the drivers side and 125 on the passenger. I have a theory that they tried to idiot proof their trucks by setting the sensor or whatever to still have 50 gallons when it reads empty. My computer read "0 MILES UNTIL EMPTY", the gauge was below the "E", and I could only cram 147 gallons in to the top, almost overflowing the tanks! I was fueling WAY too often until I figured that out, which I did VERY CAREFULLY!! I was in that truck long enough where I got a good feel for when I actually needed to fuel, and never ran out. Thought about trying to get it set more accurately, never bothered.
There is "equalizer" fitted on tot of tranny and when engine runs fuel level in tanks is equal, no matter what tank was full, what not, level goes equal. Some drivers put valves to select tank manually. BTW - not good idea to have assimetrical tanks. I used to work with Volvos (Belgium made cabovers) with different tanks. Sometimes one goes empty and engine sucks fuel with air and stalls. So I'd prefere two tanks of the same size
I see thanks guys, A low fuel light would have been nice, instead of having that needle bounce around and guessing.
