Does anyone know if having two fuel tanks of different sizes would cause a compensation problem. Let's say that having one tank of 80 gallons on the driver side and another of 120 gallons on the passenger side may cause the driver side to run empty or below the return lines.
As far as I remember, I have always seen trucks with the same capacity on both sides. Trying to find out if it is coincidence or It need to be that way. Truck is a freightliner cascadia 125 dd13.
Fuel tanks of different capacity or sizes on the same truck.
Discussion in 'Ask An Owner Operator' started by crucar1800, Mar 31, 2019.
Mine go down at approximately the same rate. 389 pete with 90 on left and 135 on right. The lowest I've ever gotten it was either a 210 or 213 gallon fill up. No issue other than me crapping my pants in fear of running out. Learned that day the last 1/8 on the gauge can sometimes mean 200 miles, other times it might only mean 30. So I don't chance it as close anymore.
Rideandrepair, Canadianhauler21, HighwaySuperTramp and 3 others Thank this. -
Rideandrepair and x1Heavy Thank this.
There’s no issue, the majority of new trucks sold have different size tanks because they have to make room for the def tank.
Rideandrepair, Brettj3876, olddog_newtricks and 3 others Thank this. -
Slap a total of 335's or 345's on there, buy enough frame for that DEF and don't worry about it for 1700 miles.
Rideandrepair and HighwaySuperTramp Thank this. -
Screw it!Rideandrepair and x1Heavy Thank this. -
Crete was buying trucks with different size fuel tanks before I left. Unless there is a fuel line blockage or you are sitting on uneven ground, the tanks equalize to the same level so there shouldn't be any issues.
Rideandrepair and crucar1800 Thank this. -
100 on one side and 150 on other side. Works great no issues yet
Rideandrepair Thanks this. -
