Fuel tank threads
Discussion in 'Kenworth Forum' started by Fishell Trucking, Aug 26, 2013.
  1. Fishell Trucking
    Fishell Trucking Light Load Member
    128
    33
    Jan 11, 2011
    Raymond Montana
    Does anyone know if they make a aftermarket fuel cap that will screw down on the fuel tank threads further than the OEM kenworth cap. I have stripped out the top threads and if I take the rubber seal out of the OEM cap it will screw down and tighten up. With the seal in the cap I can screw it down and it doesn't catch so it is always lose. Anyone have any ideas other than a new fuel tank or maybe someone can weld new threads on the old tank. Thanks
  3. truckon
    truckon Swamp Thing
    4,774
    15,920
    Dec 16, 2011
    Like I'd tell you!
    how bout just cutting a little off the top?
  4. Dieselwrangler
    Dieselwrangler Light Load Member
    128
    92
    Oct 16, 2011
    Edmonton, AB
    Oww, stop it's too big
    And then she said....
    CradleofFilth08 and 379exhd Thank this.
  5. 379exhd
    379exhd Road Train Member
    2,925
    3,160
    Jun 25, 2012
    rolling through hell
    Hey that was my line:biggrin_25510: lol
    Have you though about welding a new neck on the tank if nothing else?
  6. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    :biggrin_25525:Leave the tank about half full and then you won't have to worry about the cap not catching the threads!!!:biggrin_25512:
  7. Ezrider_48501
    3,844
    5,135
    Apr 2, 2011
    bismarck, nd
    maybe you can find a thinner gasket
  8. Ruthless
    Ruthless Road Train Member
    9,425
    94,666
    Aug 28, 2010
    The City.
    ^easiest thing to try first. Have yet to see an aftermarket cap with a longer shoulder..cutting a little off sounds simple, I'd wonder how you'd prevent dropping debris into the tank while doing it, as well as getting it perfectly even so you can catch the top threads... End up with a lot of little pieces of metal getting it just right I'd think.
  9. Fishell Trucking
    128
    33
    Jan 11, 2011
    Raymond Montana
    I found a aftermarket set of locking caps that have a deeper thread. Problem solved. 60 some dollars instead of 800-1100.
    Ruthless Thanks this.
  10. Jrtankeryanker
    Jrtankeryanker Bobtail Member
    Who makes your deeper thread cap?
