Fuel tank repair
Discussion in 'Trucks [ Eighteen Wheelers ]' started by allan5oh, Jun 2, 2014.
  1. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    What's the best way to repair a fuel tank? Re-barrell it or just put bands on? Yesterday I went to do just a quick patch job at the top of a tank where it was just barely starting to seep, as soon as I jacked it up it started dripping quite a bit out of the rear of the tank about 1/3 way up.
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I've had trouble with a few of my tanks. When you pull the straps you will find lots of corrosion. I've sent mine out to a local shop they rolled bands and welded them on. They did a very nice job and they don't look bad. A couple hundred bucks is what I paid last time.
    allan5oh Thanks this.
  4. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    If your keeping the truck long-term rebarrel it. Banding it works also but brings with it other headaches such as the saddles not being the right radius any more. Plus the possibility of leaks between the tank and the band. A good welder won't have those issues but everyone has a bad day sometimes. Where I live they want around 500 to band it and 900 to rebarell it. That's my thoughts on it.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Check into a new tank before rebarelling it. http://www.trpparts.com/Parts/Section/80/fuel-tanks
    We pay about $900 for a new tank through Peterbilt, so it doesn't make any sense for us to rebarell. We have a local welder that will put 2 bands on for $250 if we drop the tank off. We've had 3 trucks done so far with no issues.
    When we install a new tank, we put mylar tape on the tank under the straps. You can get this any any good trailer shop. It's what they put between steel crossmembers and the aluminum rails to resist corrosion. It seems to help keep the moister under the straps off the aluminum tank.
    allan5oh and Smellfunny Thank this.
  6. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Thanks for this great information, exactly what I needed. Will call around for prices and make a decision. I know one guy that does the banding and he does a perfect job. I didn't even think of the radius, and I have those big "J" brackets.
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Preventive maintenance - I was lucky, I took my tanks off for more room to pull my tranny and found a bunch of pitting where the straps angle away from the tanks and dirt settles in the crevice. I cleaned the pits out real good and primered and painted the strip where the straps lay. Some of them pits were over halfway through.
    Before I did that though I checked online and considered brazing them with some expensive rods everyone said good things about. But since I didn't have any actual holes I just opted to paint since all it cost me was time.
  8. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    What I've done in the past is purchase a damaged tank from a salvage yard. I then cut out small pieces and welded them on the leaking tank. After welding, I check for leaks using a regulated air line with soap and water. The repair can be done with the tank on or off the truck after draining.
