Fuel Tank Leveling Problem
Discussion in 'Peterbilt Forum' started by crowbar1020, Dec 29, 2011.
  1. crowbar1020
    crowbar1020 Bobtail Member
    8
    columbia, tn
    i have a 98 pete 379 with 150 gal tanks. In the last year the motor has ran out of fuel twice because of the tanks not leveling the fuel out. Two weeks ago i idled all night on a flat level surface with a 1/4 tank of fuel. When i woke i headed towards the fuel island and it died on me. Overnight the fuel moved to the right tank only and drained the left side. I have put new orings on fill caps. My truck does not have the bottom leveling line between the tanks only the main distribution block above the trans. Any help?
  3. Duramaxxed
    Duramaxxed Light Load Member
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    Several things will cause this. Plugged fuel tank vents(easiest to fix), restriction in the feed line or the drain line. Depending on the engine, the truck might also have a anti-flow back valve in the system, its a small aluminum block. It could also be bad causing this issue.
  4. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Cross over lines are no longer used to level the tanks. If it's a KW you have a valve towards the rear of the cab or sleeper between the frame rails that is responsible for levelling.
  5. Ovalhead4Life
    Ovalhead4Life Bobtail Member
    5
    7
    Jan 12, 2012
    Lehi, Utah
    There is a small fuel line connected to the top of each tank. These smaller lines come from the back of the head on your engine, returning un-burned, warm fuel to your tanks. Both lines are connected with a T fitting, ideally fuel flows to and from evenly for both tanks, levels stay the same, and they found a cure for cancer. NOT! From day 1, your 98 Pete's tanks never had the same fuel levels as long as the engine is running. Going down the road, the drivers side tank level is most always lower. In addition to the fuel lines, in the top of each tank is a pressure equalizing vent which is probably the culprit. Fuel returning from a running engine will flow to where there is less resistance; i.e. lower air pressure in one side vs. the other would see all the returning fuel go to the side where the vent is working properly, while the side with the plugged up or stuck vent has a "bubble." Clean or replace both vents, thus allowing the atmospheric pressure on top of the fuel inside the tanks to be close to even. If that does not resolve the issue, you have a blockage in a fuel line or fitting; it happens! Good luck, I hope that helps.
  6. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    I've got a similar problem on a Frlt. Could also be loose, cracked, or damaged fuel line fittings (I had a truck with a dented fitting once), trash in the line coming from one tank, or if you have tank cutoff valves, they will suck air when they get old. Could even be chafed or pinched lines.
    Slim D Thanks this.
  7. Ovalhead4Life
    5
    7
    Jan 12, 2012
    Lehi, Utah
    CAT motors also have a unique potential problem, unrelated to the fuel tank levels but it will drive you insane trying to figure out if you don't know about it or where to look. Your power drops; no check engine light. You change fuel filters... problem goes away but returns when you least expect it. You look for pinched fuel lines, have them blown out, all is well - no blockages. Weeks go by, no problems.
    Then one day, it happens. Complete fuel starvation. You change the transfer pump, no improvement. Hopefully you didn't have to be towed in. Okay enough torture. Remove the 2 bolts holding the primer pump on its housing, being careful not to tear the gasket. Better yet, get a new one and keep it in a safe place where it won't get bent. In the bottom of the primer pump, there are 2 round brown steel things pressed into the aluminum flange. They are check valves. All the fuel going into your engine goes through those valves; one faces up, the other down. If one of them gets a little loosey goosey, it can and will flip over - stopping all fuel from going through. I used to carry a spare primer pump, just in case - plus a new gasket. I once saw one of those pumps blow the plunger clean out of the housing; keeping a spare is just good PM. Make good choices! And if you are blessed with a CAT engine, be thankful and take good care of it! They don't make them any more.
    W903B, Dubbs and jr-transport Thank this.
  8. crowbar1020
    8
    columbia, tn
    first thanks for the replies. i have been having some issues with this. i am currently replacing my fuel lines from tanks to primary filter. i checked my fuel pressure before hand it was averaging 70psi at idle and 95 at 1800rpm while sitting still.
    found a few bad spots in the fuel lines and were swollen shut slightly. replacing them tomorrow and will update.
    as far as the tank vents are concerned... checked driver side tank and it does not have the factory big black vent in it. past owner must have changed it. it now has the main pickup line entering at vent hole and the vent is now in the small aux hole to right with a piece of pipe cap in it and small rubber hose connected to it. with fuel cap on i blew into it and would fill into tank and then push back out. working correctly right? the pass side tank has factory vent cap and i removed it and checked for blockage.. no sign.
    I do get a fair amount of leakage around fuel tank cap on driver side while driving. i have taken cap apart and cleaned and installed new orings and tightened main handle but no luck on stopping leak.
  9. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    My old ('88 w 3406C) 379 has had all the equalizer crap removed and a tee in the return and suction lines, both suction lines have ball valves in them so that you can shut off the draw from either tank, but with both valves open it keeps both tanks about the same.
  10. clem32
    clem32 Bobtail Member
    I have a 2004 International 9400i with no crossover line for the fuel tanks. When I only fill one tank, how do the tanks equalize if all the fuel is being returned equally from the head
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    As long as there are no leaks or blockages, the tanks slowly equalize. They are connected and the tank with the higher level will siphon into the tank with the lower level. When the engine is running, it can pull fuel from a tank with a higher level easier and return fuel easier to the tank with a lower level. So a running engine will equalize faster. They call it a dual draw system and when they are working, no crossover line is needed.
    Owens99 and Excorcist1 Thank this.
